CLUTCH LINKAGE #1784130
03/20/15 02:18 AM
03/20/15 02:18 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Pulled a slant 6 4 speed from an 80 D 100. Going back together with 340 4 speed,wondering if the z bar will be the same.
Re: CLUTCH LINKAGE [Re: rickb67] #1784131
03/20/15 11:21 AM
03/20/15 11:21 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I'm pretty sure they are for the trucks....but Brewer's and Passion should be able set you straight.
Moparlee
Re: CLUTCH LINKAGE [Re: rickb67] #1784132
03/20/15 01:59 PM
03/20/15 01:59 PM
Lehigh Acres, Florida
rickstershemi Offline
It is not the same....you will have to find a complete set of z-bars and rods from a small block v8 application
Rickster
