Re: Rod side clearance ?? [Re: MR_P_BODY] #1783915
03/24/15 08:09 PM
03/24/15 08:09 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Update. The crank was 2.004 2.006. the rods were 2.007. I machined the rods to .9935 .994 I have .0014 ish side clearance
Too tight imo..........
He has .008 clearance now.. thats even tight to me
(not the .001+ he shows)
.9935 X 2 = 1.987 2.006 - 1.987 = .0019 or .994 x 2 = 1.988 2.004 - 1.988 = .016
Unless I'm doing something wrong. And I did check it with a feeler gauge
Re: Rod side clearance ?? [Re: ChevyTS] #1783916
03/24/15 08:22 PM
03/24/15 08:22 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Chilton shows .009 to .017 I have been under the understanding that .009 to .017 would be total clearance. I have not found any information that says to measure and divide by 2. If I'm wrong I need to know asap!
Re: Rod side clearance ?? [Re: ChevyTS] #1783917
03/24/15 08:27 PM
03/24/15 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its total.. for a pair of rods
EDIT
you were correct with the .016... I entered wrong numbers
Re: Rod side clearance ?? [Re: MR_P_BODY] #1783918
03/24/15 09:49 PM
03/24/15 09:49 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Thank goodness! You had me second guessing. I havent been that nervous since that last time that I was that nervous.
Re: Rod side clearance ?? [Re: ChevyTS] #1783919
03/24/15 09:53 PM
03/24/15 09:53 PM
Az
Crizila Offline
Crizila  Offline
Az
IMO you won't have a problem with .016".
Fastest 300
Re: Rod side clearance ?? [Re: Crizila] #1783920
03/25/15 01:39 PM
03/25/15 01:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Manley recommends .014 to .020.There has been a lot of concern about side clearence,mostly having too much.We have been told they correct way to measure the clearence is to measure the journal width and then measure the width of two rod caps then do the math.We still use the feeler guage check also,but find the aforementioned process more accurate.The clearence should be set to the manufactures specs.Different rods require different clearences,like aluminium that require more clearence.More is better than less the manufactures specs.
