Re: Driveshaft U-Joint Fitment Issues
[Re: Big Bad Bee]
#1801341
04/11/15 10:54 PM
04/11/15 10:54 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I heated it up, pried with a screwdriver, tried to pull it with a magnet, prayed, waved over it a few times with my magic amulet… Zero. Can't get it out. Searched for a tool go pull it with… Zero. All I see is clam shell pullers. Anyone got a picture of the correct tool?
I’m listening.
[Re: Big Bad Bee]
#1801589
04/12/15 11:11 AM
04/12/15 11:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, there is always pulling the diff out and using a soft faced mallet to pop the pinion out the back, probably more than you want to do though.
[Re: MoParFish]
#1801644
04/12/15 01:13 PM
04/12/15 01:13 PM
RapidRobert
I did not read the whole thread but if that tapered bearing needs to come out what about drilling/tapping the face of it then slide hammering it straight back out? then purchase a new one of course. work under neath it so to keep the shavings from going inward & grease the drill bit for that also
[Re: MoParFish]
#1802332
04/13/15 01:02 PM
04/13/15 01:02 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I'm NOT saying it's textbook correct but, I have successfully replaced pinion yokes/seals several times on different applications without replacing the crush sleeve. Pinion depth won't be affected as it is set with shim behind the rear pinion bearing. Most crush sleeves take a pretty good amount of torque to "crush". If you use a souped up snap-on gun you'll crush the sleeve further. I use a new nut or at minimum red loctite. I generally use a 1/2 drive ratchet and tighten about as tight as I can get it by hand while holding the yoke with a fabbed up tool or dare I say large chain wrench , rotating the yoke as it gets tight. If once nut is tight, the yoke doesn't rotate fairly easily or is rough when rotating, then it must be redone. Not trying to mislead, just sharing another possible option and as always, this is just my This is one way to go about it, look at the torque spec for the thread pitch of the nut used and do not excee it , maybe go a little under , RED LOCTITE is your friend hear. RabidRobert , have to ever tried to drill a bearing ??? Not and option. SKF makes the tool you would need , but it's $$$$$$
[Re: Big Bad Bee]
#1802333
04/13/15 01:03 PM
04/13/15 01:03 PM
JohnRR
U.S.S.A.
Also there is no reason to pull the bearing , you can't get the crush sleeve out that way anyway.
[Re: Big Bad Bee]
#1802756
04/13/15 10:28 PM
04/13/15 10:28 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
but he machined .030 off the mating surfaces... <img src="/ubbthreads/images/graemlins/flame.gif" alt="" /> This yoke is garbage. The mating surface is not half way through the cap. A yoke should completely contain the cap. The straps will see NO torque or load, they basically are there to keep the driveshaft from falling out. Maybe another way for me to describe a proper yoke is. The cap is surrounded by 200 degrees of yoke and the strap provide the remaining 160 degrees. So even with a proper yoke, bottoming out the straps is not that critical.
[Re: Magnum]
#1803944
04/15/15 02:45 AM
04/15/15 02:45 AM
Big Bad Bee
Spokane Valley, WA
Sorry guys. I got away from this post for a day. I'm really glad you guys picked it back up. I wanted to pull the bearing BECAUSE… I thought maybe, just maybe the guy that built it replaced the crush sleeve with a cone and shim setup. I think that rather I am going to go with the by gosh and by golly method and try to get it tight enough to start feeling a little drag, mark it, pull the nut, clean the bolt and nut, red Loctite it and tighten it all back up. The weird thing is that the FSM recommends at least 170 ft lbs when not replacing the crush sleeve (They also recommend marking the nut position before you remove the damn thing…) That's quite a bit of torque, considering I tighten my lugs to 100 ft lbs and that seems like a lot. I've never tried this so I guess I'll just watch the drag and try to set it up somewhat like a front break bearing. Keep the thoughts coming. I'm ordering from Doctor Diff tonight so I can get this thing done over the weekend.
I’m listening.
[Re: Big Bad Bee]
#1804190
04/15/15 02:34 PM
04/15/15 02:34 PM
JohnRR
U.S.S.A.
Sorry guys. I got away from this post for a day. I'm really glad you guys picked it back up. I wanted to pull the bearing BECAUSE… I thought maybe, just maybe the guy that built it replaced the crush sleeve with a cone and shim setup. I think that rather I am going to go with the by gosh and by golly method and try to get it tight enough to start feeling a little drag, mark it, pull the nut, clean the bolt and nut, red Loctite it and tighten it all back up. The weird thing is that the FSM recommends at least 170 ft lbs when not replacing the crush sleeve (They also recommend marking the nut position before you remove the damn thing…) That's quite a bit of torque, considering I tighten my lugs to 100 ft lbs and that seems like a lot. I've never tried this so I guess I'll just watch the drag and try to set it up somewhat like a front break bearing. Keep the thoughts coming. I'm ordering from Doctor Diff tonight so I can get this thing done over the weekend. I wanted to say it was something that high of a torque value , it takes more than that to start crushing the sleeve. Torque value is based on diameter and number of threads per inch , the pinion stem is double the size of a lug nut.
[Re: JohnRR]
#1804736
04/16/15 03:26 AM
04/16/15 03:26 AM
Big Bad Bee
Spokane Valley, WA
Sorry guys. I got away from this post for a day. I'm really glad you guys picked it back up. I wanted to pull the bearing BECAUSE… I thought maybe, just maybe the guy that built it replaced the crush sleeve with a cone and shim setup. I think that rather I am going to go with the by gosh and by golly method and try to get it tight enough to start feeling a little drag, mark it, pull the nut, clean the bolt and nut, red Loctite it and tighten it all back up. The weird thing is that the FSM recommends at least 170 ft lbs when not replacing the crush sleeve (They also recommend marking the nut position before you remove the damn thing…) That's quite a bit of torque, considering I tighten my lugs to 100 ft lbs and that seems like a lot. I've never tried this so I guess I'll just watch the drag and try to set it up somewhat like a front break bearing. Keep the thoughts coming. I'm ordering from Doctor Diff tonight so I can get this thing done over the weekend. I wanted to say it was something that high of a torque value , it takes more than that to start crushing the sleeve. Torque value is based on diameter and number of threads per inch , the pinion stem is double the size of a lug nut. Makes total sense. Great yet simple explanation. Thank you, john.
I’m listening.
[Re: Big Bad Bee]
#1808835
04/21/15 07:33 PM
04/21/15 07:33 PM
JohnRR
U.S.S.A.
Any sealer of some sort , pick your poison.
