Re: 5.9 Magnum engine and head help.
[Re: FatherSonRacing]
#1783089
03/18/15 09:10 PM
03/18/15 09:10 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
They are pretty much ALL cracked, of course out of all the dodge trucks runnning around I never see any with a cloud of smoke following them so I just run em and don't lose any sleep over em any more. I have built tons of them and never had one come back complaining about coolant loss. I used to get them pressure tested at the machine shop but they never found any leaking so I don't even do that any more. They are the best SB head the factory ever made, not just flow but tons of other improvements. The are not the best flowing mopar head ever... Pretty much any hemi heads from the 60s on flows better and the max wedge heads. They make as much HP as any run of the mill BB head.
#1783090
03/18/15 09:17 PM
03/18/15 09:17 PM
dogdays
Well you can buy them directly from EngineQuest, also from Brian at IMM in California, from Hughes Engines, and many other places. But first, back up, pardner! You just CANNOT believe everything you hear. Many, probably the majority of Mag headed engines out there, have over 100,000 miles on them and are being used. It's true that Mag heads have the tendency to crack between the intake and exhaust valves, but those heads came this way from running engines and the cracks don't leak. Mag heads are not the best flowing wedge heads Mopar has produced, that used to be W2s. The mag head has three advantages: 1. Really good exhaust port. 2. Really good chamber as long as you get the piston up to zero deck or close. 3. Decent flow. Now, porting can change anything, but no way would I pay money to get Mag heads ported. The EQ heads are better to start with. There are also RHS heads which come from a really good head manufacturer, but seem to be a little behind EQ heads out of the box. Then trailing back there are the Chinese copies. So in closing, your engine will probably not develop external combustion because of the Mag heads, but there are versions out there that work better. They might be out of your financial grasp at the moment. Get your vehicle on the road and have fun with it or it'll become a garage queen. Follow the link below, they're the first head on the page. http://www.aamidwest.com/index.php/enginequest/eq-cylinder-heads/chrysler-magnum-head/R.
[Re: dogdays]
#1783091
03/18/15 10:20 PM
03/18/15 10:20 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Mild budget economy build? run the stock heads. they'll support 400 crank hp as-cast, and the cracks are not detrimental. If you're worried about the set you have, then take them to your machine shop and have them leak and pressure tested, to make sure that A) coolant won't leak into the chamber, and B) compression won't leak into the ports.
but if it were mine, I'd run it.
**Photobucket sucks**
[Re: 70Cuda383]
#1783092
03/18/15 11:27 PM
03/18/15 11:27 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I agree 100% with this post, I put a set of stock magnum heads that were"cracked" between the valves on my Father's 1990 ramcharger that I swaped a 360 magnum into. Four years later still runs great, no water loss or compression loss.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
#1783094
03/19/15 09:51 PM
03/19/15 09:51 PM
Posts: 15,487 Florida
scratchnfotraction
A hughes whiplash roller cam/spring package is hard to beat in a stock magnum engine. my stock JY 91 LA318 whiplash roller cam engine is still scratching. my 440 truck just got a whiplash installed. freakin awesome in a BB 440 truck. just picked up a 98 5.9 360 that will be getting the 360 magnum whiplash roller for the w350 cheapest bang for the buck running Junk from the yard
[Re: scratchnfotraction]
#1783095
03/21/15 11:17 PM
03/21/15 11:17 PM
70Cuda383
Marysville, O-H-I-O
That combo got me 285 rwhp 325 rwtq
Started as stock 5.9. Swapped to a thinner head gasket, added the whiplash cam, and since it was an EFI truck, I added a 2bbl M1 intake, cheap mid-length headers, and reprogrammed the stock EFI computer with SCT. Even had the stock restrictive throttle body and those nasty cracked stock heads.
You should have the same results with a 750 CFM carb, a nice dual plane intake, and headers.
[Re: moparmandjh]
#1783097
03/22/15 01:19 PM
03/22/15 01:19 PM
70Cuda383
Marysville, O-H-I-O
You won't be able to run stock tune with a whiplash cam, but with SCT to reprogram the stock computer, the stock computer, sensors etc will work fine with that cam
[Re: d-150]
#1783100
03/23/15 10:14 PM
03/23/15 10:14 PM
slammedR/T
with the wiplash cam do u have to cut the valve guides down?
stock guides are good up to .520" lift before you will smack the guide top.
Edit with more info; stock valve springs and retainers are only good to .520" lift. Hughes springs and retainers package for magnum heads will give anoth ".100" of lift allowance on stock magnum heads.
[Re: 70Cuda383]
#1783103
03/24/15 01:30 AM
03/24/15 01:30 AM
Posts: 1,089 st.cloud fl
d-150
Smarter than a 5th grader?
st.cloud fl
[Re: 70Cuda383]
#1783104
03/24/15 08:37 PM
03/24/15 08:37 PM
slammedR/T
Whiplash has .544 lift and all that's needed is to run the matched valve springs and the set of retailers that Hughes calls for. It's a bolt in/on cam. No machine work needed to any parts. And as long as it's installed to the card (installed centerline of 104), there's no risk of piston to valve contact either.
Edited my original post to include that figure is on stock valve springs and retainers.
[Re: slammedR/T]
#1783105
03/25/15 11:33 PM
03/25/15 11:33 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
The stock Mag valve springs are really wimpy anyways. I'd think they probably float when the revs get high on a stock engine.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
