Re: Trans cooler line PSI for a 904 ?
[Re: belv2vert66]
#1782980
03/18/15 06:41 PM
03/18/15 06:41 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Would that be less of a rating than a rubber hose and clamp? I think most cars have rubber tubing on most of them that are running the streets.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: belv2vert66]
#1782981
03/18/15 06:52 PM
03/18/15 06:52 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Even with raised line pressure the cooler circuit should be below 50 psi.
BTW, 37° lines aren't normally double-flared; single-flare lines run over 3000 psi in aircraft.
