Ok guys 1st of all no crapping on my thread or else.....
![](/ubbthreads/images/graemlins/eeek.gif)
I am a phone call away from ordering my cylinder heads!!! BUT I cant make up my mind? why cause Im Bi Polar I guess I dont know..... a few questions questions!
1st -- Im getting Indy EZ heads but can decide which ones the 295's or the 325's.
I have all the goodies for the 295's so I guess I need offset intakes only for the 325's if I go that route!
Long valve stem design
325cc intake port volume
***Stock exhaust port location***
Full CNC port 325 cc intake
Stock pushrod location
***Offset intake rockers needed***
440-1 shaft oiling
78cc closed or 82 cc open cbr
2.19 x 1.81 valve 370 CFM
295cc intake port volume
Full CNC port 295 cc intake
440-1 shaft oiling
Max Wedge intake opening
78cc closed or 82cc open cbr
2.19 x 1.81 valve 355 CFM
MCH's are like the 295's but a 308ish volume version??? maybe that route??? I still think they flow about the same a the 295's though... dunno?
My car is a 3800lb street car and do mostly street driving and my cam is a comp solid roller 248/254... now some of you already said that a small roller for the 325 but I am upgrading ALOT lately so a new cam is on my list but last...
Is it worth the 15 cfm of flow over the 295's and is the 325 heads really streetable even with the right cam...
Also I have a aeromotive 150gph fuel pump... is it time to upgrade that also....
Sincerely'
Bench Racer in Training!
