loose lifter bore?
#1781245
03/16/15 01:55 PM
03/16/15 01:55 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Putting everything back together after freshening at machine shop and noticed that one of the Comp roller lifter links "clicked" each revolution. Upon further inspection I found that just this one lifter bore is loose or worn. The lifter has a lot of play in that bore. Am I looking at having all bushings installed? At least I found this before I had the motor completely together and in the car Thanks Mike p.s. What is the going price of having the bores bushed?
Re: loose lifter bore?
[Re: 70satelliteguy]
#1781252
03/16/15 06:38 PM
03/16/15 06:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is on a MP Mega block Mike
I bushed the lifter bores on my new mega block right from the get go... I didnt bother to measure them since it was gonna be a high rpm roller set up... how long has this engine been running that its got a bad lifter bore
[Re: MR_P_BODY]
#1781253
03/16/15 09:48 PM
03/16/15 09:48 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Been running this block for 8 seasons. Never noticed the problem before .All the other seem to be ok. Just glad I found it before running it this year. Could have had the lifter break and take the motor out!!! I did find a shop that has done Mopars before and as soon as I get it all back apart again I will have them bush this bore and check the others. Mike
[Re: MR_P_BODY]
#1781255
03/17/15 11:22 AM
03/17/15 11:22 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Measure all of them but you can have just the one bushed
Since he is running rollers that are linked together it would be smarter to have the pair bushed.
There is little guarantee that the lifter bore geometry is right to begin with, unless the shop doing it is just going to bush the bore in it's present angles, which may or may not be correct.
#1781256
03/17/15 11:25 AM
03/17/15 11:25 AM
JohnRR
U.S.S.A.
Depending on when it was done , and who did it ... Cummins Recon .... , you would be dollars ahead just having all the bores bushed while it's in the fixture.
Figure $750 for the whole job?
