727 trans build part 2 #17794
10/25/05 12:38 AM
10/25/05 12:38 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Part two consists of the front drum . For this build I am using Alto red racing clutches and Koline steels. If all goes well I sould be able to fit five clutches in the front drum for more holding ability in high gear.
The pressure plate was de-glazed using a crossbuff. I also de-glazed the drum surface with a crossbuff.
Here is a pic of the assembley lube I will be using during the entire build.
All of the seals on the drum and piston were lubed with assembley lube before installation. Make sure the lip of the seals are facing down twards the drum.
The next step is to install the piston. Make sure the seal surfaces on the drum are lubed up also. Try to apply even pressure with your hand and seat the piston.
Next step is to install the springs. Mine came with 9 and are installed as such.
The next step was to compress the springs and install the lock ring that holds the spring retainer in place. I used a floor jack and two pieces of wood butted up aganst my shop celing. Don't try this at home!!! Use a press or go to a trans shop and let them do it.
Pictured here is the installation of the steels and clutches. Clutches should be soaked with trans fluid for 15 miniutes before installation. after all five were installed I cheched the gap between the pressure plate and the retainer ring. Ah, a perfect .070
stay tuned for part 3, the rear drum!!
Re: 727 trans build part 2 [Re: ccdave] #17795
10/25/05 01:28 AM
10/25/05 01:28 AM
Really big pics, can you shrink em?!!
Re: 727 trans build part 2 #17796
10/25/05 02:00 AM
10/25/05 02:00 AM
808CUDA Offline
808CUDA  Offline
PERFECT Timing!
I have to rebuild a '71 727 soon and this will do teh trick!
Thanks a bunch!
Where do you get your clutch plates/trans parts?
Is this trans being built for strip only or can be used for street duty?
Thanks,
Gil
Re: 727 trans build part 2 [Re: 808CUDA] #17797
10/25/05 02:46 AM
10/25/05 02:46 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Thats one way to compress the springs that I have to admit I never thought of.
Re: 727 trans build part 2 [Re: GomangoCuda] #17798
10/25/05 03:35 AM
10/25/05 03:35 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Never thought of that either!
Re: 727 trans build part 2 [Re: ccdave] #17799
10/25/05 12:18 PM
10/25/05 12:18 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
pictures are to big!
good tech. though
Re: 727 trans build part 2 [Re: ccdave] #17800
10/25/05 03:12 PM
10/25/05 03:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Good series of info.
Attached is a pic of the factory spring compressor in the manual. I made one based on this pic and it works nice. Just tighten the bolt.
Re: 727 trans build part 2 [Re: ccdave] #17801
10/25/05 04:22 PM
10/25/05 04:22 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Good pictures and good tech info.
I have my Dart up on stands now, getting ready to pull the 727 for a rebuild.
If need be, can I PM you for advice?
Thanks.
Re: 727 trans build part 2 [Re: 340727dart] #17802
10/25/05 07:31 PM
10/25/05 07:31 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
I'm not an expert on 727 trans builds. I'm learning as I go. I hope to post best practices based on imput from several good sources. I must say that a lot of how these transmissions are built and modified is based on personal preference. Carl Munroe wrote a book on " How to rebuild and modify the 727 Torqueflight". A great resource.
Re: 727 trans build part 2 [Re: ccdave] #17803
10/25/05 07:34 PM
10/25/05 07:34 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Sorry bout the big pic's. the next set will be smaller.
Re: 727 trans build part 2 [Re: ccdave] #17804
10/25/05 08:34 PM
10/25/05 08:34 PM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
hey 440 jim here is a picture of the 727 a-518 / 618 46,47,48 rh,re miller tool used to compress the ft spring in the clutch pack
THIS TOOL ALSO INSTALLS THE REAR OUTTER SPRAG IN THE BACK OF THE CASE
Re: 727 trans build part 2 [Re: 727jim] #17805
10/25/05 08:37 PM
10/25/05 08:37 PM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
here is the one for the 904,998,999 a-500 42,44 rh and re ft clutch spring compressor see atachment
Re: 727 trans build part 2 [Re: ccdave] #17806
10/25/05 08:38 PM
10/25/05 08:38 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Very good! After finishing it... someone should put it in the tech articles!
It's good to have big pics for better resolution and to see the details!
1973 Brasilian Dart
E100, boosted 390"
Re: 727 trans build part 2 [Re: ccdave] #17807
10/25/05 08:39 PM
10/25/05 08:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
FYI,
In photobucket you can checkbox each photo and click on the generate HTML tags at the bottom of the page. Use the thumbnail for message board links. Copy and paste, done deal. You can write notes inbetween each pic as you have been. It will do something like this for you and not kill the folks with dial up.
Then the viewer of the post can click on it if the want the bigger pic.
I'd keep saving the pics to photobucket as you have been. The big pics are great for detail.
Great thread.
HTH
Rob
Re: 727 trans build part 2 [Re: 727jim] #17808
10/25/05 08:40 PM
10/25/05 08:40 PM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
CLOSER PIC OF THE MILLER SPECIAL TOOL
Re: 727 trans build part 2 [Re: ccdave] #17809
10/25/05 10:31 PM
10/25/05 10:31 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
I bought that book a couple of weeks ago. When I first looked at it, I was quite intimidated by the transmission. Now that I've read it at least 7 times, I'm ready to tear into it.
I have spent the past couple of days making all the tools as outlined in chapter 5 of the book.
Re: 727 trans build part 2 [Re: 340727dart] #17810
10/29/05 11:55 AM
10/29/05 11:55 AM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Arent't the pictures showing anymore?!?
1973 Brasilian Dart
E100, boosted 390"
Re: 727 trans build part 2 [Re: ccdave] #17811
11/17/05 12:30 PM
11/17/05 12:30 PM
Bern, Switzerland
6o4o Offline
6o4o  Offline
Bern, Switzerland
Are this pictures already gone?
