Dana rearends-- car vs truck #1780628
03/15/15 03:53 PM
03/15/15 03:53 PM
Mi.
G-Money1320 Offline OP
Mi.
Is there any way or ways to identify a car dana from a truck dana?. I looked at a Dart yesterday for the second time that has a dana installed with 3" inboard spring locaters and was wondering how to tell what the true application of the dana was. Thanks.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Dana rearends-- car vs truck [Re: G-Money1320] #1780629
03/15/15 04:02 PM
03/15/15 04:02 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
A car Dana 60 will have provisions to mount a pinion snubber. The truck units will not.
Re: Dana rearends-- car vs truck [Re: G-Money1320] #1780630
03/15/15 04:03 PM
03/15/15 04:03 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I believe all the car danas have a pinion snubber mount and none of the trucks do.
Re: Dana rearends-- car vs truck [Re: forphorty] #1780631
03/15/15 04:15 PM
03/15/15 04:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
On the back side of the right axle tube will be the 6 digit BOM # and with the aid of a Dana/Spicer catalog you can identify the original application...only if the original tubes are still in place, of course. OEM car Danas are few and far between and really don't justify a premium price tag.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana rearends-- car vs truck [Re: Polarapete] #1780632
03/15/15 06:38 PM
03/15/15 06:38 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
What he said. You can find the catalog on one of the truck axle parts vendors web site. As I remember I found mine buy googling "dana 80 parts"
By the time you're done buying the parts and labor to convert a truck axle, it's close enough to a Strange or Moser built D60 to justify buying one of theirs. They will even weld in the spring perches in the right place for a small fee.
Re: Dana rearends-- car vs truck [Re: Lefty] #1780633
03/15/15 08:27 PM
03/15/15 08:27 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Many trucks have 30 spline axles.
Cars have 23 or 35 depending on year.
I know someone the cut down a truck axle and used 30 spline axles from a 8.75 rear.
Re: Dana rearends-- car vs truck [Re: B5 Bee] #1780634
03/15/15 11:54 PM
03/15/15 11:54 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My 60 had 35 spline axles, it depends on the truck application. Many Fords had 35 spline in the 3/4 ton with a dana 60 front and 23 spline with the 44 front. Dodge was similar. Camper specials also could have 35 spline. There was also a 16 spline in the early 60's. I found a power lock and 35 splines for $75 and you CAN build a 60 for less than a grand if you use stock gear, stock power lock and get the core for around $100, shortening is only around $275, shafts from Dutchman are less than $500, its doable if someone is willing to do their own work. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
