installing 4 speed hump in 66 belvedere ll #1780590
03/15/15 02:25 PM
03/15/15 02:25 PM
Wi
sunbee Offline OP
sunbee  Offline OP
Wi
I'm converting my 3 on the tree /6 to a 383 4 speed. When welding in the hump do I trace the hump and cut all metal out or do I cut a small portion of metal out and weld in the hump? Seems to me I should trace the hump, then cut all metal out then weld hump in place. Thoughts or pics? Thanks
Re: installing 4 speed hump in 66 belvedere ll [Re: sunbee] #1780591
03/15/15 02:42 PM
03/15/15 02:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Trace it, and then retrace inside about an inch. Cut the inside line and cut all the metal out, BUT STOP where the torsion bar cross member is. Don't cut the floor pan there or else stuff can collect in there. DAMHIK.
