Is synthetic oil in 04 4.7 grand cherokee a good idea? #178052
12/29/08 04:04 PM
12/29/08 04:04 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Would it benefit me to switch to synthetic oil in my jeep's 4.7? Pros? Cons?
Re: Is synthetic oil in 04 4.7 grand cherokee a good idea? [Re: OA5599] #178053
12/29/08 04:11 PM
12/29/08 04:11 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Great idea. Better flow in cold temperatures, lower boil off rate when compared to conventional oils, more stable viscosity and capable of longer drain intervals between oil changes.
Re: Is synthetic oil in 04 4.7 grand cherokee a good idea? [Re: OA5599] #178054
12/29/08 04:17 PM
12/29/08 04:17 PM
United States
STLDuster Offline
STLDuster  Offline
United States
Up until about 90,000 miles I ran Ford Motorcraft Oil 10W40 in mine. When the price of gas jumped up I swapped over to Mobil 1 Full sythetic, that winter my 4.7 started to "tick" on cold starts. Once the oil pressure built up it went away. I went back to the Ford MotorCraft Synthetic Blend and have used it along with a WIX filter for a long time. Just recently I changed over to the new formula Rotella Oil.
I asked the same question when I switched to Mobil 1 Full synthetic, should I really have any problems? Other than a little bit of gas mileage increase I didn't really show much of an improvement. Although my WJ has a lot of miles (140,000) on it so take it for what its worth...
http://www.youtube.com/watch?v=P5UMT6Tob9Q
"No great genius has ever existed without some touch of madness." - Aristotle
