Re: Comp Cams XE275HL enough vacuum for Power Brakes?
[Re: Bdrainy]
#177949
12/29/08 02:00 PM
12/29/08 02:00 PM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
I have that cam in my 470, except Dwayne had it ground with a wider lobe separation. I love the cam, but I'm not sure how it'd do with power brakes. Mine pulls low to mid teens for vacuum so I can't imagine a 383 would be able to hold a ton of vacuum.
Darrah Heath
[Re: Bdrainy]
#177950
12/29/08 02:04 PM
12/29/08 02:04 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I have the same cam in a 318 stroker 390 cubes and it is still pretty mild. Power brakes work fine. My engine does have a 4.00" stroke crank and the stock stroke 383 is a 3.38?? I don't know if that will make a big difference or not but I think it is a factor even though we have the same size engine. For the street I think this cam is pretty close to perfect and I still have a nice rumble at idle. I am also using 1.6 rockers so my lift is up around .565
Maybe some of the engine building guru's can shed some light on the effect of stroke on cam size???? TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: Bdrainy]
#177954
12/29/08 04:51 PM
12/29/08 04:51 PM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
I had that cam in my 4 - speed RR, didn't care for it not enough torque down low for a heavy 4-speed car. Just put in a 268/276 Lunati VooDoo cam and it has a much broader power band especially off idle. As for the power brakes you will be fine, I have no complaint there.
BTW, my motor is the original 400 block with a 440 crank, eddy heads and 3.55 gears.
