need A8 REAR MAIN SEAL #1778977
03/13/15 05:31 PM
03/13/15 05:31 PM
San Angelo, Texas
W8n2DustU Offline OP
San Angelo, Texas
Where do I get one? Bennett is ready to finish it up and needs one. I looked online and seen a few that say they will work but no pictures. Bennett said it needs two ears sticking off of it to go through pan to keep it in place.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: need A8 REAR MAIN SEAL [Re: W8n2DustU] #1778978
03/13/15 10:50 PM
03/13/15 10:50 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
check with mr p body on that one,being a factory guy he prob can help you out.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: need A8 REAR MAIN SEAL [Re: W8n2DustU] #1778979
03/13/15 11:53 PM
03/13/15 11:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What are you building a a8 motor for.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: need A8 REAR MAIN SEAL [Re: 1967dartgt] #1778980
03/14/15 01:24 AM
03/14/15 01:24 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Kent Ritter?
Re: need A8 REAR MAIN SEAL [Re: Darryls-Demon] #1778981
03/14/15 01:49 AM
03/14/15 01:49 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Kelly Hammack.
Honestly, I'd try Kent Ritter as well.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: need A8 REAR MAIN SEAL [Re: 1967dartgt] #1778982
03/14/15 02:33 AM
03/14/15 02:33 AM
San Angelo, Texas
San Angelo, Texas
My P5 uses an A8 block.
Re: need A8 REAR MAIN SEAL [Re: W8n2DustU] #1778983
03/14/15 07:54 PM
03/14/15 07:54 PM
dakotawilly Offline
dakotawilly  Offline
i dont know much about those myself,i was under the impression that they had a 340 main size,doesnt the std 340 seal work in that? had a chance to buy one when i was running small block stuff,but the timing gears and other parts cost scared me away....
