Where can I get exhaust mani hardware? #1778324
03/12/15 11:21 PM
03/12/15 11:21 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
So we bought a motor/trans combo with everything separated, and we are getting ready to put the exhaust manifolds back on the 97 5.9 Magnum, and there is nothing there, no bolts, washers, or studs.
Where can I get Magnum V8 exhaust manifold mounting hardware? There has to be a kit out there someplace, right? A Google search turned up nothing. Gene
Re: Where can I get exhaust mani hardware? [Re: poorboy] #1778325
03/13/15 01:43 AM
03/13/15 01:43 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
ACE hardware should have everything you need. Studs, nuts, washers if necessary.
Re: Where can I get exhaust mani hardware? [Re: stumpy] #1778326
03/13/15 10:17 AM
03/13/15 10:17 AM
scratchnfotraction Offline
auto parts store in the DORMAN line exhaust studs/bolts
dealer will have them for the magnum manifolds in a set also.
hardware store = measure correctly for fitment in the blind holes.
I may have a set of stock used ones.
I have 2 sets of manifolds that I removed from trucks for headers. I should be able to scratch them up if you need them.
Re: Where can I get exhaust mani hardware? [Re: scratchnfotraction] #1778327
03/13/15 09:47 PM
03/13/15 09:47 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Scratchnfortraction,
I appreciate the offer, but we will probably just pick up some bolts locally. Since the bolts will work, we can have it together before your stuff can ever get out of Florida.
The weather has finally turned warm, and for some reason, my son is ready to move forward. Something about wanting to drive this car this spring/summer.
Will grade 5 bolts work, or will we need grade 8 bolts?
Gene
