Holley Ultra HP E-85 Carb Sticking #1778207
03/12/15 10:00 PM
03/12/15 10:00 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Is it common for these carbs to stick in wide open position brand new right out of the box? Seems to be secondary side causing the issues, so do they need tweeking normally? This is a little disconcerting to say the least for a road race application.
Re: Holley Ultra HP E-85 Carb Sticking [Re: jcc] #1778208
03/12/15 10:04 PM
03/12/15 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No you shouldnt stick... but make sure the carb isnt
on backwards.. if I pull the pass side it will stick
Re: Holley Ultra HP E-85 Carb Sticking [Re: MR_P_BODY] #1778209
03/12/15 10:22 PM
03/12/15 10:22 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Definitely pulling on the Drivers side, seems to only stick wide open, just not what I want in the back my mind approaching my braking zone at the end of each straight. I'll return it in a heartbeat before I dig into it if this is not common as you suggest. Thanks
Re: Holley Ultra HP E-85 Carb Sticking [Re: jcc] #1778210
03/12/15 10:27 PM
03/12/15 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the linkage looks the same but the one side pulls easy
and doesnt stick
