Lower control arm removal; '98 Dodge Ram SS/T
#177697
12/29/08 08:56 AM
12/29/08 08:56 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... Hope everyone's doing ok and all had a Merry Christmas and Happy Holidays..
Situation: I'm about to replace the upper/lower control arm bushing and ball joints on my '98 Ram SS/T..
Question: Since there's a coil spring, can I:
1. put the truck on jack-stands with the weight of the truck on them 2. raise the lower control arm with a floor-jack and with the arm up, compressing the spring, separate the lower ball joint, and then lower the control arm slowly thus allowing the lower control arm to swing down far enough to release it from the coil spring.
OR: Do I HAVE to use a coil spring compresser?
I'm sure the upper control arm's removal is similar to my old b-bodies in that I just need to separate the upper ball joint from the spindle and then remove it from the frame eccentric locations. I'll be marking the position of the eccentric cams so I can repposition them in the same location..
I'm trying to do this all myself other than the press work required for the bushing and ball joint installation itself.
Thanks.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Lower control arm removal; '98 Dodge Ram SS/T
[Re: hemi68charger]
#177698
12/29/08 09:26 AM
12/29/08 09:26 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
if the ram is similar to the dakotas then a spring compressor is not needed. A floor jack is the way I have done it many of times. Just be careful the spring is under a lot of compression force. Also removing the old ball joints is a pain in the butt, If you can find a shop to do it for a couple hundred then have them do it. You might also want to check your bushings, when my ball joints needed to be replaced so did my bushings.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#177699
12/29/08 09:37 AM
12/29/08 09:37 AM
hemi68charger
Houston, Tx
As far as the components go, I'll be taking the upper and lower control arms once off to a shop to have the joints/bushings pressed out/in.. Not looking to tackle that without air tools(maybe next Christmas )
Are you referring to pain as the removal of the joints out of the control arm themselves? If so, I'll be doing what I mentioned in the previous paragraph.
Thanks...
[Re: hemi68charger]
#177700
12/29/08 05:50 PM
12/29/08 05:50 PM
blk00rt
Michigan Troll
if you are just removing the arms then it is not too bad, though my regular impact gun would not brake the bolts loose. (IR 231 about 325 ftlbs) The bushing had caused some binding issues and would not allow the nuts to turn. I wound up borrowing a IR Titanium (800 ftlbs) and it removed the bolts.
[Re: blk00rt]
#177701
12/29/08 10:18 PM
12/29/08 10:18 PM
hemi68charger
Houston, Tx
Well,, turned out to MUCH EASIER than I thought it was going to be.. Luckily I have a lot of experience with our older B's, so this wasn't so daunting. Took me about 1.5 hrs to get one side off. The other side should be far quicker with the driver's side under my belt....
The fruits of my effort.. Tomorrow to the machine shop to press out/in the new bushings and ball joints.. The tierod ends all seemed to be in good shape since those had zerts to grease...
Thanks to ya'll for your replies..
[Re: hemi68charger]
#177702
12/29/08 10:18 PM
12/29/08 10:18 PM
hemi68charger
Houston, Tx
Everything pretty much out that I need.....
[Re: hemi68charger]
#177703
12/29/08 10:19 PM
12/29/08 10:19 PM
hemi68charger
Houston, Tx
one side done and ready for new "stuff"...
[Re: hemi68charger]
#177704
12/31/08 06:17 PM
12/31/08 06:17 PM
I just finished this process a few months ago. I used Energy Suspension Bushings. I did all the work myself. Not sure I would do it all over again though, especially with a truck that did time up North and then down in Florida. I went a head and lowered it 3" in the front and 4" in the rear, while I was at it. I wasn't going to disassemble the suspension a second time if I could help it. The truck handles much better now and looks good with it's new stance.
