Re: Need help finishing off inside of enclosed car trailer
[Re: StrokedW7]
#177557
12/28/08 10:59 PM
12/28/08 10:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Steve, are the walls done or is it studs and outter skin. Home depot or maybe craigslist for cabinets. My old trailer, I found some used cabinets local to me, a guy was remodeling some apartments and he had a pile to pick from then I bought a counter top at Home Depot. If you need wall material I would call the trailer places in Indiana. I just re-did my currant trailer and bought the white alum for the walls and ceiling(about $800 in alum) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#177558
12/28/08 11:04 PM
12/28/08 11:04 PM
Posts: 2,333 Kalamazoo, MI
StrokedW7
Kalamazoo, MI
Hi Mike, Its just studs and outer skin... ![](/ubbthreads/images/graemlins/crazy.gif) I actually thought about doing exactly what you did with the diamond plate on bottom. I was thinking I might be able to use the stuff that is used in bathrooms... that shiny white "stuff". Steve
[Re: StrokedW7]
#177560
12/28/08 11:19 PM
12/28/08 11:19 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
Hi Mike,
Its just studs and outer skin... I actually thought about doing exactly what you did with the diamond plate on bottom. I was thinking I might be able to use the stuff that is used in bathrooms... that shiny white "stuff".
Steve
I would consider plywood on the walls and then the bathroom wall stuff on top of the plywood.I have diamondplate floor but next time I would go with the rubber coin floor.Another way to do the walls is the plywood and garage floor paint on it or carpet halfway up.The plywood is important to hang all the crap you end up with on the walls and you dont have to look for a steel stud .
[Re: cudabunch]
#177561
12/28/08 11:25 PM
12/28/08 11:25 PM
StrokedW7
Kalamazoo, MI
Hi Mike,
Steve
Yes... I should have said that. Plywood is real important.
BTW - What is "rubber coin floor"
Steve
[Re: StrokedW7]
#177564
12/28/08 11:35 PM
12/28/08 11:35 PM
MR_P_BODY
Hi Mike,
Steve
If your talking the white press board stuff... dont. I tore that stuff down(I put that up first) because if it gets wet.... it gets bad and buckles... but I had a roof leak... which I fixed. I bought the diamond plate from Jack Moore here on the board, he's in the Columbus area.... very good price and he also can get the white alum... I'd talk to him FIRST. Make sure you insulate it also, I used 1" of the blue styfofoam on the walls and ceiling ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#177566
12/28/08 11:47 PM
12/28/08 11:47 PM
StrokedW7
Kalamazoo, MI
No Im talking about the real thin shiny white stuff they use in bathrooms. You have to glue it to the walls. Im not sure if its actually plastic or not.
Steve
[Re: StrokedW7]
#177567
12/29/08 12:05 AM
12/29/08 12:05 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
This is similar to what what my trailer looked like when new.. ![](http://i172.photobucket.com/albums/w29/Jeepmon/Trailer/Before1.jpg) Then the mods.. 1) Epoxy paint.. needed 2 gallons ($120-ish) 2) White paint on the wood panel, grey indoor/outdoor carpet on the lower half, trim and misc hardware ($200ish) 3) Cheap plastic cabinets from Home Depot.. ($175-ish) 4) Misc trailer caddy stuff bought from Summit Racing ($400-ish) The trailer is still not finished, as I want to re-arrange stuff and install the tool box.. THE FLOOR ![](http://i172.photobucket.com/albums/w29/Jeepmon/Trailer/Wench1.jpg) THE CABINETS ![](http://i172.photobucket.com/albums/w29/Jeepmon/Trailer/P1000785.jpg) OVERALL ![](http://i172.photobucket.com/albums/w29/Jeepmon/Trailer/P1000780.jpg)
[Re: MegaDart]
#177571
12/29/08 09:10 AM
12/29/08 09:10 AM
StrokedW7
Kalamazoo, MI
Here is how I did one recently. Total cost of materials about $500
What did you use for trim on the floor, ceiling and top of carpet?
Do you glue the carpet on? If so, did you just use liquid nails?
Steve
[Re: StrokedW7]
#177572
12/29/08 09:46 AM
12/29/08 09:46 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I had my floor painted with grey paint, but carpeted it last year. Makes it nice when the car is out as we often use the trailer for a living space at the track. I prefer the wood panel walls. Easy to hang stuff as mentioned, and won't scuff/dent easily like the aluminum interiors. Here's some toys: http://www.blazinbelltech.com/I've bought a few items from these guys as they are right up the road from me in Vegas.
