Re: My 337 MW intake....
[Re: Streetwize]
#1775013
03/25/15 06:22 PM
03/25/15 06:22 PM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
Any plans to take it down the dragstrip?
[Re: an8sec70cuda]
#1775014
03/25/15 09:01 PM
03/25/15 09:01 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I'd like to get a back to back 440-2D vs 337 at Zmax, they're opening back up for Test n tune in a couple weeks.
Being an original R/T 4 speed Dana car I'm ( understandably) a bit reluctant to beat on it too bad like I did from the early 80's to mid 90's ( before they were worth more than 4 yrs of college tuition, lol) can't afford to restore it again. The motor belongs in an A body post car ( like it was supposed to go in). But a couple passes at Zmax should do both the car ( and me) some good for old times sake.
[Re: BradH]
#1775021
03/26/15 05:34 PM
03/26/15 05:34 PM
Posts: 74 virginia
tigger1
virginia
I just purchased a new 337. I ordered it late December and it arrived in February.
Twin turbo 440 72 barracuda
[Re: BradH]
#1775024
03/26/15 06:15 PM
03/26/15 06:15 PM
Streetwize
Weddington, N.C.
That's similar to the one like I bought from you, wasn't it Brad? The one Roger (Dr Air) Ported? Except that one was a 4150 flange.
Was going to use it but wound up putting the Chapmans on a Low deck instead.
[Re: Streetwize]
#1775026
03/26/15 06:23 PM
03/26/15 06:23 PM
BradH
Yep, that's how I recognized it as not being a 337.
The RB Stage VI intake has that same extreme taper from the runner entry down to the head opening, too. I think on a 500-ish (+) combination it helps the mid-to-top, but on a 450-ish like I dynoed it on, it had a big hole in the curve under the torque peak (but it did make a lot of HP up top).
[Re: Streetwize]
#1775027
03/27/15 01:09 AM
03/27/15 01:09 AM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
You and Old School with your 572" RB's , my 517 B is just a 'lil small block by comparison!
yeah, I'm looking forward to trying it out, maybe this week-end, looks like I'll need to fab up a new Regulator bracket which will take me 3x what it takes to swap the manifold itself, lol
Do you have any plans for the old intake? Looking for a used Indy dual plane to mess around with.
[Re: Blues_Cuda]
#1775028
03/27/15 09:44 AM
03/27/15 09:44 AM
Streetwize
Weddington, N.C.
Blues,
To be honest I have a TON of work in that manifold and it works awesomely so I doubt I will be turning it loose.
I'm not really sure what all the fuss is about with the 337, if you go to the tech Archives on Firefighters 572" (!!!) motor the Port matched (but still unported) 2d was only down 4hp (717 to 721) and 7 lb/ft (697 vs 705) to the 337, that's hardly a runaway victory (about 2/10th of 1 Per Cent) in my book. Dyno numbers are one thing, but roll-on part throttle torque (ie, "real world driving" is is almost always going to favor a 180 dual plane.
on a 750+ hp high RPM motor I would expect the difference to be more dramatic but up to 700 and especially with an automatic I don't think I would call the single plane a big (or even a noticeable) advantage, and at 470 to 500" I would think the advantage might likely be less noticeable or may actually be in the dual planes favor (in terms of average torque)
In my own case now I have a fully ported to fully ported comparison, I want to spend a day on the Chassis dyno and then hopefully Z-max at a Test & tune, but that will likely be after I swap back to the 833 4 speed. Ootb I didn't feel the 337 would have had any appreciable advantage over the max ported 2D so I never was too motivated to swap it.
It's not readily apparent from the pics but Larry did a lot of whittling on the 337, it should work really well. The ports are a good bit larger than before the walls between the runners are a good bit thinner, it's not just a polish job by any stretch for sure.
