Re: My 337 MW intake....
[Re: Streetwize]
#1774973
03/08/15 11:30 PM
03/08/15 11:30 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Bobby, please post some pics when you get it back. Is he doing plenum work too?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: The Cuda Guy]
#1774976
03/10/15 04:28 AM
03/10/15 04:28 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I have this Vintage NOS Edelbrock intake for a low deck motor which I hear they only made a few years..Id like to put it on a 512 stroker build for my 63 to keep with a max wedge theme..Ive heard bad stories about blowing the lid open on these intakes from poor flow and fuel puddling..I would like to know if your guy could give me any help bullet proofing this intake..??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: Cab_Burge]
#1774982
03/10/15 10:02 PM
03/10/15 10:02 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
[Re: ScottSmith_Harms]
#1774987
03/11/15 12:40 AM
03/11/15 12:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
FWIW I have messed around with multiple Xram setups using dual 3/4" pop offs over the years (30 or so years), most were Hemi's and small blocks. To date I've never had an intake crack when it "sneezed", the valves did their thing. Having said that, a larger opening with a plate, or more valves, wouldn't hurt any, the more pressure relief and the faster, the better.
Why the 140PSI valves, waaaay to much, IMO. The manifold is normally under vacuum .
I don't think I would want any more then +50 PSI in that intake.
[Re: Streetwize]
#1774988
03/11/15 12:45 AM
03/11/15 12:45 AM
Sport440
Canton, Ohio
And now back to our regularly scheduled broadcast
Larry is done with the manifold ( the one without a pop-off valve, lol) I'll try to post pics in a day or 2
Oh yeah, I forgot this was your thread.
I saw your vid before of your 512ci charger. It does sound mean as hey.
I forget, what cam and comp, do you have in that beast that makes it sound like that.
[Re: Sport440]
#1774989
03/11/15 01:41 AM
03/11/15 01:41 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I meant to comment on that....To clarify, I didn't customize his intake, I just offered him the idea. I am also a proponent of a very soft valve, because, as you pointed out, the intake is under vacuum, no need for a high pressure opening valve.
[Re: Streetwize]
#1774990
03/11/15 10:08 AM
03/11/15 10:08 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Bobby... if you don't mind me asking, what does it cost to have him port a manifold? Wonder if he's ever whittled on a Barton hemi manifold? You can PM me w/ cost if you want. I've always wondered if there is any real benefit to having the manifold fully ported. Not flow bench results, but timeslip results.
[Re: an8sec70cuda]
#1774991
03/11/15 12:41 PM
03/11/15 12:41 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Chip, every intake I have ever run gets ported. Since I ported Nesbitt's intake he can't control wheelstand issues. I put in 2 hours work on Terry Shaw's intake just trying something that I thought would help and he picked up 1 mph and it will pick up more because it was very lean and his heads are stock.
Nesbitt's intake
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
