What did I screw up? New question.......
#1774778
03/08/15 02:37 PM
03/08/15 02:37 PM
Posts: 16,841 Between Houston & Galveston TX
SattyNoCar
In an effort to boost the MPG on my Dakota, decided to put plugs and plug wires on it this morning. Found this little gem when I pulled the cap off....... Now, mind you, it started fine and seem to run fine. No obvious miss or real roughness. Put all my parts on, WOW!!! What a difference! It was almost buttery smooth and I now had a traction problem taking off from a dead stop (roads are damp, wasn't doggin' it). Got home, turned it off. Cleaned up my work area, went to leave again, and, its running worse than poo......stalling, running REAL rough. Huh? When I parked it, it was fine. Doing nothing but letting it sit and restarting it, it runs terrible. Its bad enough I can't drive it. I've double checked my work. Double checked the cap, can't find any issues. I'm at a loss. Ideas?
John
Re: What did I screw up?
[Re: SattyNoCar]
#1774779
03/08/15 03:06 PM
03/08/15 03:06 PM
SattyNoCar
After typing that post, I went out, re-rechecked my work, still found nothing wrong, fired it up, and it was buttery smooth again. Drove it 2 miles with no issues, still smooth. Maybe computer was adjusting to new parts?
John
[Re: SattyNoCar]
#1774780
03/08/15 05:09 PM
03/08/15 05:09 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I had a similar problem when I changed the battery on my Ram. After a couple of minutes running it smoothed out and ran fine. Did you disconnect the battery?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#1774781
03/08/15 08:22 PM
03/08/15 08:22 PM
SattyNoCar
Just got back from a 30 mile round trip. Truck ran flawlessly.......as long as it was moving. If I stopped briefly for a stop sign, it would dead miss once. If I stopped for a lengthy light, it would dead miss up to 5 times. By 'dead miss' I mean a miss that you couldn't help but notice, not one of those soft ones where you're not sure if it did it or not. And of course, its raining steadily now, so, I can't look at it anymore today.
John
[Re: rickstershemi]
#1774783
03/08/15 08:40 PM
03/08/15 08:40 PM
SattyNoCar
Cap too. There was a pretty good gouge from where the rotor hit.... Marked each wire, and pulled cap off with wires in place. Installed new cap and followed wiring order from old cap. Checked, rechecked, and checked again that I didn't bust or pull loose a vacuum line that runs across the back of the engine. I'm lost.
John
[Re: rickstershemi]
#1774786
03/08/15 09:15 PM
03/08/15 09:15 PM
SattyNoCar
No NAPA's close, went with BWD brand. The cheap Chinese caps were smooth inside, no ribs. The BWD cap has ribs inside and looked/felt like the better piece. I used Autolite plugs and wires. The truck had Champions in it, but, I've ALWAYS had problems with Champions, never had an issue with Autolites. Plug wires, basically the same deal as the cap. Didn't want the cheap chinese junk, but, didn't see the need to fork over $$$ for something like MSD wires, especially for a 150K 3.9 V6.
John
[Re: SattyNoCar]
#1774788
03/08/15 10:22 PM
03/08/15 10:22 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Make SURE the cap is fully secured with BOTH screws fully engaged. DAMHIK
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: d100dragracer]
#1774790
03/08/15 10:28 PM
03/08/15 10:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I bet whoever screwed up the cap/rotor job before you twisted the distributor to get it to run, now it needs twisted back to the correct position.
Pull the cap, twist the crank till it is at TDC and check to see if the rotor is pointing at the "1" on the cam plate (if 180 or so out turn the engine one revolution) then if it is off twist the distributor to line up the "1" and the tip of the rotor.
It is more accurate with a scanner but this will get it close enough to run correctly.
[Re: HotRodDave]
#1774791
03/09/15 12:13 AM
03/09/15 12:13 AM
SattyNoCar
Yes, screws for cap are tight, and I made sure no wires were pinched and the mounting service was clean. I carefully blew out all the plastic bits the original cap left behind (didn't use full pressure on the air hose). When the weather breaks, I'll check timing. I'm kinda at the mercy of the weather, and of course they say its supposed to rain all week. Thanks guys.
John
[Re: SattyNoCar]
#1774792
03/09/15 01:19 AM
03/09/15 01:19 AM
Posts: 954 garnett kansas
rhad
garnett kansas
my 92 dakota does the crappy run after shutdown,been doin it for years,started about the same time as the fuel started getting changed for emissions,its really bad in warm weather by the way my dist isnt moveable.there is a slot it the shaft that the hold down fits into and holds it in one place,also a bad crank sensor will make it run bad after a warm shutdown,ive heard of people slotting the holes in the crank sensor to advance the timing some,i never tried it
my ladder of success is missing some rungs
[Re: rhad]
#1774793
03/09/15 01:28 AM
03/09/15 01:28 AM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Wrong answer. Your magnum distributor moves like any other. Important point the distributor in a 92 or newer magnum motor does not adjust the timing. It only sets the cam reference signal. There is a procedure to do this. There is also a TSB for lower drive bushing wear and shaft wear.
[Re: NITROUSN]
#1774794
03/09/15 01:46 AM
03/09/15 01:46 AM
HotRodDave
Kalispell Mt.
Correct. The drive ability problem is not from the fuel timing being messed up it is from the wrong plug getting fire.
[Re: HotRodDave]
#1774795
03/10/15 02:28 AM
03/10/15 02:28 AM
rhad
garnett kansas
take a good look at a 92 dist,on the housing there is a cut back spot where the hold down fits into,with a different style or modified hold down it can be made to turn,look up a picture on rock auto,you can see the recessed place on the body of the housing
[Re: Dodgeguy101]
#1774797
03/11/15 07:18 PM
03/11/15 07:18 PM
Posts: 8,185 Plymouth, MI
Blusmbl
Plymouth, MI
The last set of Autolites I put in a vehicle (a '79 Jeep CJ7) I was not happy with, it had a miss until I reinstalled the old plugs. If they didn't look fouled I'd try putting the old plugs back in it just to eliminate the plugs as a cause.
