w8 vs w9 vs 9rp #1772960
03/06/15 12:16 AM
03/06/15 12:16 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
What makes the most steam and why
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: w8 vs w9 vs 9rp [Re: WHITEDART] #1772961
03/06/15 12:18 AM
03/06/15 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
W-8 port can be BIG flow
Re: w8 vs w9 vs 9rp [Re: MR_P_BODY] #1772962
03/06/15 01:09 AM
03/06/15 01:09 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I have a raw set of Zeus cast W8s (sans plug) and have been told by those who should know that it has the highest potential. They are heavy.
I'm sure Brett Miller could chime in and give you a good answer since he works on these castings.
Re: w8 vs w9 vs 9rp [Re: jim sciortino] #1772963
03/06/15 01:12 AM
03/06/15 01:12 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Seen some big numbers out of the RP heads, I think CFE said 450cfm. Whether or not that means it would make the most power I cannot say
Re: w8 vs w9 vs 9rp [Re: SpareParts] #1772964
03/06/15 02:51 AM
03/06/15 02:51 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
RFD did a set of W9RP for a N/A application that was above 440.Too bad the block let go on the cars second pass with those heads but they survived.LOL.Might see that combo at DW 15.
Re: w8 vs w9 vs 9rp [Re: ksj] #1772965
03/06/15 03:46 AM
03/06/15 03:46 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
You're right, it was RFD, I couldn't remember. Any details you can share on what the combo was?
I didn't think about it earlier but I think the crown might belong to a set of PST W8's
Re: w8 vs w9 vs 9rp [Re: SpareParts] #1772966
03/06/15 01:10 PM
03/06/15 01:10 PM
Out West
408strokerdart Offline
Out West
I'm not sure huge flow numbers contribute to the biggest success of these engines. Lots of other factors to consider. I have never personally seen a set of RP heads be successfully used on a drag engine.
Re: w8 vs w9 vs 9rp [Re: 408strokerdart] #1772967
03/06/15 01:58 PM
03/06/15 01:58 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
The RFD heads are for Mike Crows 69 Dart 426,g-force 5 speed car.Still unsure what caused the bottom end to let go.Split an R3 block and bent the crank etc.I haven't talked to him in awhile.Alot more than total cfm plays into a good head job.Curtis does awesome work.
