Page 2 of 3 1 2 3
Re: whose the fastest on an 8 3/4 [Re: MR_P_BODY] #1771438
03/04/15 10:26 PM
03/04/15 10:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Somebody should come up w/ some type of formula that takes into account car weight, engine HP & torque, 60-ft, ET, MPH, etc., to be able to define a factor to use in comparing these.
I have a formula.........when it breaks, you have gone too far with weight and or power............LOL!!!
then you can buy a new tranny to boot....
That ISNT FACT... when I blew the stock 8 3/4 I
pulled the trans to make sure.. it was fine.. still
running the same trans and the same sprag
it is fact I can show you the pieces
You act like EVERY one will blow the sprag... NOT..
and I have a trans that says so
I didn't say that, but the chances are pretty good
Re: whose the fastest on an 8 3/4 [Re: Quicktree] #1771439
03/04/15 10:31 PM
03/04/15 10:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Then it's not a fact, just a highly probable outcome.
Re: whose the fastest on an 8 3/4 [Re: Quicktree] #1771440
03/04/15 10:32 PM
03/04/15 10:32 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
When I broke my passenger car 9 in rear I took my stock 727 trans out because I was afraid I killed the sprag but everything was fine so I told the guy to put it back together.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: whose the fastest on an 8 3/4 [Re: BradH] #1771441
03/04/15 10:33 PM
03/04/15 10:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
isn't that the same?
Re: whose the fastest on an 8 3/4 [Re: Quicktree] #1771442
03/04/15 10:44 PM
03/04/15 10:44 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
my opinion is, years in use is the biggest killer.
metal fatigue of the housing flexing over and over.
the older it is, the less force it takes to meet the fail line. the axle housing flexes putting extreme pressure on the caps in turn binding carrier eventually the gears cant handle the extra pressure. then new stronger gears are put in,same thing happens to axles so their replaced so now the carrier cant handle the strain, then comes a spool.. then the caps fail. so a new pumpkin is used.. the housing ignored most all the time...
Re: whose the fastest on an 8 3/4 [Re: Quicktree] #1771443
03/04/15 10:47 PM
03/04/15 10:47 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have been 8.57@162 while weighting 3195. It has a 422 small block on spray in it. Only had 225 hp in it. The rear is still in n car and making passes. On another note when it sheared the ring gear bolts I pulled the trans apart and the sprag was fine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: whose the fastest on an 8 3/4 [Re: 1967dartgt] #1771444
03/04/15 10:53 PM
03/04/15 10:53 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I have been [Email]8.57@162[/Email] while weighting 3195. It has a 422 small block on spray in it. Only had 225 hp in it. The rear is still in n car and making passes. On another note when it sheared the ring gear bolts I pulled the trans apart and the sprag was fine.
Man oh man! U R pushing your luck,
Re: whose the fastest on an 8 3/4 [Re: BradH] #1771445
03/04/15 11:06 PM
03/04/15 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BOTH YOU and Tony fail to ask the FIRST question and
the MOST important... is it a 904 or 727... a 904
is unlikely to blow it... a 727 MIGHT blow it IF it
was above 6200 rpm
Re: whose the fastest on an 8 3/4 [Re: MattW] #1771446
03/04/15 11:08 PM
03/04/15 11:08 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
He knows
Us small block guys don't give a damn about stuff lol
Re: whose the fastest on an 8 3/4 [Re: MR_P_BODY] #1771447
03/04/15 11:14 PM
03/04/15 11:14 PM
BradH Offline
BradH  Offline
BOTH YOU and Tony fail to ask the FIRST question...
Actually, I didn't ask ANY question. I simply stated that it's not a FACT (as Tony claimed) if there are examples that people have broken their diffs WITHOUT having subsequent transmission damage.
E-nuff of this. I have a beefed-up 8.75" and haven't broken it, but am upgrading my rear axle assembly so I'm not the next guy who has to end his day-at-the-track story with "... and then I broke the rear end."
Re: whose the fastest on an 8 3/4 [Re: BradH] #1771448
03/05/15 12:43 AM
03/05/15 12:43 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think Ron Nies' 63 is putting a lot of hurt on his 8-3/4, considering mid 10's in a B-Body that I'm sure weighs in at least 3600. His rear is pretty stock too, with a locker being the only upgrade I've heard him speak of.
Re: whose the fastest on an 8 3/4 [Re: wyldebill] #1771449
03/05/15 01:02 AM
03/05/15 01:02 AM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
I've been 9.40's with mine.
Re: whose the fastest on an 8 3/4 [Re: onefastindy] #1771450
03/05/15 01:08 AM
03/05/15 01:08 AM
K
KOS Offline
KOS  Offline
K
ive been low 10s @3300lbs for 3seasons and never hurt anything.ive had good luck with 4.88s gear sets seems the thicker the ring gear they seem to last.ive ripped the teeth off of many 4.10s...too bad they dont offer a pro gear in a variety of ratios for the 8.75
Re: whose the fastest on an 8 3/4 [Re: KOS] #1771451
03/05/15 01:26 AM
03/05/15 01:26 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
In my Demon I broke the teeth off a set of 4.30's (7.20's in the 1/8)and one of the caps on the 8 3/4 with a set of 5.13's ( spraying 100 shot of Nitrous)and of course half the teeth off of the ring gear after that. The spider gears were welded together on both of them ( Poor mans locker).
Re: whose the fastest on an 8 3/4 [Re: D-50] #1771452
03/05/15 11:41 AM
03/05/15 11:41 AM
Guitar Jones Offline
Plenty of guys faster than my pile, see sig. Mine has the aluminum center section and pro gears, 30 spline spool and axles at 2760 pounds. Haven't broken a ring gear since going to the pro gear.
Re: whose the fastest on an 8 3/4 [Re: Guitar Jones] #1771453
03/05/15 12:54 PM
03/05/15 12:54 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Wafflebatter has been in the 5.30's I believe with his 1900# Roadster..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: whose the fastest on an 8 3/4 [Re: 1967dartgt] #1771454
03/05/15 01:26 PM
03/05/15 01:26 PM
an8sec70cuda Offline
11.40s at 3700# broke the 8.75 suregrip. Upgraded to a spool and 35 spline axles.
When I put the Indy headed 440 in the car, the 8.75 sheared the teeth off the pinion and got some of the ring gear at 10.70s at 3700# while trying to sort out the new combo. After that, I put the Dana in and wound up going 10.40s all sorted out.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: whose the fastest on an 8 3/4 [Re: an8sec70cuda] #1771455
03/05/15 03:49 PM
03/05/15 03:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
There is a lot to goes into it, that's why people have so many different opinions on it.
Everything has a fatigue life... crank shafts, ring gears, axles, etc...
The harder you stress anything (either more power or more weight), the shorter the lifespan of the part will be.
My 3.23 gear (heavy load) sheared the pinion off... didn't even make it 50 passes behind my 3700lb mid/low 10 second tuneup. But the STOCK axles survived.
Lots of guys have broken axles without hurting ring gears.
It's not one thing that fails, or one weight, or one power level, its a combination of things.
Generally though just from what guys have done, regular 3300lb race weight is good down to around 10 flat or so. There are certainly failures at that point, and certainly people that have gone quicker... but it's a good rule of thumb that will PROBABLY ensure a reasonable lifespan out of the parts.
For the record, my clean break on the pinion killed the sprag too. I highly recommend that you ALWAYS at least look at the sprag if you hurt the rear axle/u-joint.
Re: whose the fastest on an 8 3/4 [Re: BradH] #1771456
03/05/15 03:58 PM
03/05/15 03:58 PM
BradH Offline
BradH  Offline
I have a beefed-up 8.75" and haven't broken it...
... yet.
Details HERE, FWIW.
This was taking mid 1.4 60s and mid 10s at 3750+ #s.
Never broke a stock axle, but saw others do it at lower performance levels.
No problems w/ rebuilt Power-Lok sure-grip units, but broke a couple of Auburns when the car was much slower and simply gave up on that design.
As was stated above, it's definitely a combination of factors that contribute to what & when something breaks.
Re: whose the fastest on an 8 3/4 [Re: BradH] #1771457
03/05/15 04:27 PM
03/05/15 04:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a set of Strange 35 spline axles that had a
full spline width twist in the splined end right out
from the spool.. they were still working but I changed
them out only because I had another set of them.. I
paint a white line down the whole length of each axle
just to monitor the twist... the stock 8 3/4 that I
first started out with had stock axles... they had
just over a full twist in the length.. they didnt
break either but I knew it wasnt gonna be to long
for them... but then I blew the cap off the center
and thats when I changed to the alum center and the
good parts.. that was right at 600 passes on the stock
8 3/4 with 1.24-1.26 60'
Page 2 of 3 1 2 3
