whose the fastest on an 8 3/4
#1771418
03/04/15 07:05 PM
03/04/15 07:05 PM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
I know thumper dart has gone mid 9's. Who's gone faster, what's in it?
Re: whose the fastest on an 8 3/3
[Re: wyldebill]
#1771425
03/04/15 07:32 PM
03/04/15 07:32 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Any idea what was done to it?
I think it had a spool...That's it. But it was a rail that weighed about 1,800 lbs if I remember correctly.
Re: whose the fastest on an 8 3/4
[Re: wyldebill]
#1771426
03/04/15 07:34 PM
03/04/15 07:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm running 8.90s with a 1.19 60'
[Re: BradH]
#1771428
03/04/15 08:41 PM
03/04/15 08:41 PM
Posts: 4,703 Wichita
GY3
Wichita
Somebody should come up w/ some type of formula that takes into account car weight, engine HP & torque, 60-ft, ET, MPH, etc., to be able to define a factor to use in comparing these.
Looks like you just volunteered..
[Re: GY3]
#1771430
03/04/15 09:07 PM
03/04/15 09:07 PM
BradH
NFW... I'm moving on from this sillya$$ debate!
[Re: BradH]
#1771432
03/04/15 10:05 PM
03/04/15 10:05 PM
MR_P_BODY
I have always said its weight that kills the 8 3/4.. greater weight has greater friction on the track.. and the weak point is the caps if its back braced
[Re: BradH]
#1771433
03/04/15 10:13 PM
03/04/15 10:13 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I have a formula.........when it breaks, you have gone too far with weight and or power............LOL!!!
[Re: Monte_Smith]
#1771434
03/04/15 10:15 PM
03/04/15 10:15 PM
Quicktree
then you can buy a new tranny to boot....
[Re: Quicktree]
#1771435
03/04/15 10:18 PM
03/04/15 10:18 PM
MR_P_BODY
That ISNT FACT... when I blew the stock 8 3/4 I pulled the trans to make sure.. it was fine.. still running the same trans and the same sprag
[Re: MR_P_BODY]
#1771436
03/04/15 10:21 PM
03/04/15 10:21 PM
Quicktree
it is fact I can show you the pieces
[Re: Quicktree]
#1771437
03/04/15 10:23 PM
03/04/15 10:23 PM
MR_P_BODY
You act like EVERY one will blow the sprag... NOT.. and I have a trans that says so
