2005 Magnum 5.7 multiple cylinder misfire ? #1770006
03/03/15 01:16 PM
03/03/15 01:16 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
I have an 05 5.7 Magnum and its getting multiple cylinder misfire code along with like 4 other cylinder codes. It has had plugs, wires and coil packs with in the last year and a half. Could it be the computer. I have heard bad things about these computers.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 6PacCuda] #1770007
03/03/15 05:23 PM
03/03/15 05:23 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Most common issue is a broken valve spring.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 71yelladustr] #1770008
03/03/15 11:22 PM
03/03/15 11:22 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
So far no broken valve springs. Burnt coils again.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 6PacCuda] #1770009
03/04/15 12:41 PM
03/04/15 12:41 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Is the car as delivered or have you added any electronics? Boom box, speakers, amp, etc? Your PCM is a computer with several high capacity transistors driving the coils. Sometimes adding electronics to a car can create a ground plane fault that will not allow the coil drivers to go to zero. There's a lot more to it but the bottom line is it can create a lot of heat in the coils/wiring. A fresh coil can tolerate this for a while but the heat will get it sooner or later. It's why there's a warning about adding stuff to the electrical system of new cars. Good luck.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: Cudajon] #1770010
03/04/15 12:52 PM
03/04/15 12:52 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
Factory everything on the inside. Only changes to it are fresh air and muffler delete.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 6PacCuda] #1770011
03/04/15 10:13 PM
03/04/15 10:13 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Find someone with a diagnostic oscilloscope, I prefer a Pico. Take a look at whayts happening. A bad PCM will be readily evident. Save some money. Replacing parts to find a problem can really cost you.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 6PacCuda] #1770012
03/05/15 01:24 AM
03/05/15 01:24 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Multiple misfire codes can go with a bad fuel pump , or in a charger you have a transfer pump too.Connect a fuel pressure gauge to it and drive around.
Re: 2005 Magnum 5.7 multiple cylinder misfire ? [Re: 71yelladustr] #1770013
03/06/15 08:54 PM
03/06/15 08:54 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
The grand majority of valve spring issues are found on 03-early 04 truck motors.
Although likely an electrical/cpu issue, some of the 05-06 motors have had issues with failing (sometimes falling) valve seats.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
