727 Trans governor support removal
#1769554
03/02/15 09:31 PM
03/02/15 09:31 PM
Posts: 957 MI, Lapeer
maximus
MI, Lapeer
Working on my 727 transmission and will be tossing the governor support assembly. Thinking of making a bolt-on aluminum flanged spacer to take up the gap for the park brake assembly and oil passage blocking. What are you guys doing for this modification? Also, anybody ever lighten up the sun gear?
Re: 727 Trans governor support removal
[Re: dvw]
#1769556
03/03/15 02:07 PM
03/03/15 02:07 PM
dartman366
Mt. Vernon, Ohio
I just use a spacer and the origional clip to hold it in place on my 904's
[Re: maximus]
#1769558
03/03/15 04:28 PM
03/03/15 04:28 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want to delete both the governor assembly and its support, all you have to do is remove them from the output shaft...no further action is required. Obviously, doing so will also delete the Park function.
A spacer of some kind is required if you only want to delete the governor assembly and leave the support in place.
[Re: maximus]
#1769564
03/04/15 09:07 PM
03/04/15 09:07 PM
Posts: 9,857 MI, usa
dvw
MI, usa
All good info, thanks guys. Now what about lightening the sun gear? Anybody do any mods in this department?
I think you're referring to the park pawl gear? I removed the governor. Then the rear was faced off until the teeth were .275" thick. The front half was cut down so the the thickness of the entire unit is .830". It weighs 14 oz. Doug
[Re: maximus]
#1769566
03/05/15 07:10 AM
03/05/15 07:10 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
If you follow John's link, it will show Jamesc lighting a sun gear SHELL. Which, in my opinion, will result in zip. Also, the gutted governor housing is so light, I don't worry about it either. If you own a mill, and want to use it, carve away, it's a matter of personal preference.
[Re: Leigh]
#1769567
03/05/15 09:33 AM
03/05/15 09:33 AM
dvw
MI, usa
Ah the sun shell. I removed 1 lb. along with swapping my A&A steel drum for an aluminum part (7lbs total) it picked up a solid .10 in the 1/8 thru the 1/4. 2 mph in the 1/8, no more mph in the the 1/4. Doug
