Re: Popping through carburetor during acceleration
[Re: roadhazard]
#1768761
03/02/15 03:01 AM
03/02/15 03:01 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
As stated above , cam lobe, also check to see if you have a plug wire mixed up, possible cracked distributor cap? Bent intake valve, broken intake valve spring.
[Re: moparjim87]
#1768762
03/02/15 05:00 AM
03/02/15 05:00 AM
Posts: 43,179 Bend,OR USA
Cab_Burge
as a problem, and have installed/tried factory adjustable rockers. There's a brand new cam and lifters in it, and when we swapped the intake, the cam looked in good shape. Any and all help is appreciated.
It sounds like you have the lifters preloaded to much, try going back and readjusting the preload so you have no more than 1/2 turn of preload after making sure you have the adjusters looses enough to have a tiny bit of up and down rocker movement at TDC of each cylinder on the firing stroke before setting the rocker adjuster preload Do this on a cold or slightly cool motor, not on a hot motor the first time Loosen the rocker adjusters up enough so they becomes loose enough to have some lash between the rocker arm tip and valve stem, tighten it up slowly until the lash is gone, try turning the pushrod with your fingertips while doing this also, when the lash is removed the pushrod should spin harder Take your time to make sure you get zero preload and zero lash, once you got that, tighten the adjuster up between 1/3 and 1/2 turn more and lock down the locknut tightly while making sure the adjuster doesn't tighten up anymore Do one cylinder at a time and go to the next one I try to do them in the firing order on most stock motors that don't have a fully degreed harmonic balancer, dampener, to work off of It might be best to start on number one(verify that it is on the firing stroke, not the overlap stroke ) and then turn the crankshaft 90 degrees clockwise and do the next one, #8, turn another 90 degrees and then do #4 and so on. The Mopar V8 firing order is the same as BB and SB Chevys, 1-8-4-3-6-5-7-2. Let us know if that helps or not
[Re: moparjim87]
#1768763
03/02/15 12:09 PM
03/02/15 12:09 PM
Posts: 7,506 Az
Crizila
Az
My first guess is it's going lean - especially if it occurs after the peddle has been on the floor for a bit ( upper RPM range). Check fuel delivery first.
Fastest 300
[Re: dynamite]
#1768765
03/02/15 02:45 PM
03/02/15 02:45 PM
Posts: 109 Indiana, PA
moparjim87
Indiana, PA
Egr deleted, stock stamped rockers back on it, timing on cam is correct, exhaust sounds glass smooth at idle and under load, cap/wires/rotor/plugs all new, heads are completely new (redone with new valves/springs/locks/retainers), and 1406 edelbrock carb, just rebuilt by my dad yesterday. This engine did this with the fuel injection on it also, which is why we put a carburetor and old school electronic ignition on it, thinking it might have been a problem. The throttle response is now where it should be, and it is definitely running alot better, just no power and pops through the carb. (not backfire popping, just like its pushing compression back through the intake. My dad has been building engines for the better part of 30 years, and he adjusted the valves when we tried the adjustable rockers, so I know they were good. We were trying to figure out whats possibly wrong, and we thought one or more lifters on the intake were pumping up when the oil pressure is higher, thus holding the intake valves open..... (sorry for being long winded, just trying to give any and all info so youns get the whole picture)
[Re: moparjim87]
#1768766
03/02/15 02:51 PM
03/02/15 02:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do a compression test and a leak down.. see if your bleeding off pressure to the intake side... but the spark chases the fuel so its telling you its on the intake side
[Re: moparjim87]
#1768768
03/02/15 03:16 PM
03/02/15 03:16 PM
MR_P_BODY
We leak checked all 8 cylinders and they were all under 3-4% leakage. It only pops when you rev it up and idle is glass smooth. Like I was saying, we've checked pretty much every parameter of the engine that could be a problem. The only thing that is still the same is the fuel delivery system which is the stock in-tank pump with a mallory adjustable bypass fuel regulator, and it is set to 6 psi at the carb.
Next question... does it only do it at temp or cold or both... is the vent on the tank clear... also is your gauge mounted under hood.. if so.. is that gauge liquid filled..if it is.. drain it.. that type of gauge will give you bogus reading when hot
[Re: moparjim87]
#1768770
03/02/15 03:51 PM
03/02/15 03:51 PM
MR_P_BODY
It pops hot or cold, temp doesnt matter, and the gauge is liquid filled, but is accurate, we've had this regulator setup on another truck and haven't had a problem with it.
Drain the gauge... I know for FACT it WILL give you a bogus reading.. if you keep turning down the pressure its just gonna lean out... and its not the regulator that has the problem.. its the gauge.. reason is that the liquid inside it heats up and presses on the internals to give a high reading
[Re: MR_P_BODY]
#1768771
03/02/15 04:10 PM
03/02/15 04:10 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Well based on what everyone has suggested and your response, im betting you have a cam lobe out and you missed it when you inspected it or valves are too tight. I may have missed this in your post but are you running a vacuum advance if so plug it off. May be over timing for your combo.
JAKES AUTOMOTIVE
