Page 3 of 4 1 2 3 4
Re: Hemi Vs Wedge Debate [Re: Al_Alguire] #176854
12/28/08 08:15 PM
12/28/08 08:15 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Seems pretty simple. If the hemi was the be all and end all of naturally aspirated engines they would be ruling the heads up classes of the world. I think we can all agree that they do not do that.
funny, alot of n/a heads up classes ban the Hemi. I wonder why
Re: Hemi Vs Wedge Debate [Re: HotRodDave] #176855
12/28/08 08:32 PM
12/28/08 08:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
A hemi port does not have to be huge to flow like crazy, look at the new version hemi for proof, ports are no bigger than a SB head but can easily flow way over 300cfm like a heavily ported W2.
Huh? A factory Hemi port is 1.84" x 2.00", thats 3.68 in^2. My fullly ported w9's are only 1.4" x 2.2" that's 3.08 in^2. My heads are 20% less port size then the hemi, and they flow about the same if not better...
(stock hemi port we're talking of course...)
The hemi head probably has the biggest port ever produced aside from the ford tunnel port stuff or a Ram Air 5...
Re: Hemi Vs Wedge Debate [Re: Defbob] #176856
12/28/08 08:32 PM
12/28/08 08:32 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
To put something simple, I don't think a max effort Wedge (B1 or Predator heads) can out run a max effort Hemi (lets say with Millenium Heads). Most Hemi's I've seen, other than S/S Hemi's are not set on kill. Probably because the owner doesn't want to risk blowing the motor up. and they seem to run with the "set on Kill" mopar wedges. most people with Chevies, fords and mopar wedges don't seem to have the fear taking the risk of pushing their motors to their limits. Personally, I would have a fear of pushing my motor too far, despite having a bryant crank, oliver rods and a dual cross bolted block. I just can't afford to risk having to buy those parts all over again. if I had more cash I would go for it. Even Darren's motor is not at its full potential. SS Hemi's have larger cams than his. He designed his motor to fit a certain competition.
Just imagine what SS hemi's could make if they were allowed a lighter rotating assembly. or if they threw on a set of ported Millenium heads?
Re: Hemi Vs Wedge Debate [Re: Defbob] #176857
12/28/08 09:01 PM
12/28/08 09:01 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
the 440 wedge was never meant to be what the 426 hemi is
the block is weak
2 bolt mains
small port heads
if the max wedge moter was built past 1964 the maxwedge head would have improved , instead it was dropped to build the 426 hemi
as migthy as the hemi is
the wedge head stands beside it
two diffrent engines
compare the 426 hemi to fords 427 - 429 hemi
1.39 9.85 - 137 mph
Re: Hemi Vs Wedge Debate [Re: Ari440] #176858
12/28/08 09:06 PM
12/28/08 09:06 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
If I've said it once, I've said it a million times: There are Hemis and then there's everything else...
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Hemi Vs Wedge Debate [Re: maundmotorworks] #176859
12/28/08 09:28 PM
12/28/08 09:28 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Hemi's will always be #1
let's see a conventional headed wedge make as much power as a conventional Hemi. can't be done. only Pro Stock style wedges can compete
Re: Hemi Vs Wedge Debate [Re: dizuster] #176860
12/28/08 10:21 PM
12/28/08 10:21 PM
nc
moeflo Offline
moeflo  Offline
nc
Huh? A factory Hemi port is 1.84" x 2.00", thats 3.68 in^2. My fully ported w9's are only 1.4" x 2.2" that's 3.08 in^2. My heads are 20% less port size then the hemi, and they flow about the same if not better...
Huh? A stock 426 port has less area than a BBC rectangle port, Boss 302/351/429 or Ford SCJ as well as the ones you mentioned. Normally I don't compare flow rates between OE and race heads, but if thats allowable, a 6.1 hemi can flow around 400 CFM with a 2-1/8th valve.
Re: Hemi Vs Wedge Debate [Re: 67HEMI] #176861
12/28/08 10:41 PM
12/28/08 10:41 PM
As long as it is a Mopar I am ok with it. Just one question, how many all motor wedge cars that weigh 3320 or whatever SS/AH minimum is, have run 8.30's @ 157 with less than 440 inches? Not very many that I know of. They are either super light, have 500 plus inches,or have nitrous or forced induction.
It might be very interesting to drop a 438 fully preped Max wedge motor in a SS/AH car..Of course use a sheet metal intake...Those cars have more tricks, ie.. suspension, trans/converter, weight disturbution than most would belive...The hemi would be faster due to the better factory heads..
I would bet the wedge would be well into the 8's as well
Re: Hemi Vs Wedge Debate [Re: dizuster] #176862
12/28/08 11:31 PM
12/28/08 11:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Funny I said "new hemi and W2" and you come up with "old hemi and W9" I don't know if a max ported W2 can flow 400 CFM but a ported 6.1 hemi head will and there not too far different in size, as best info as I can find on port size the W2 port is bigger. A more apropriate comparo would be the Max effort 6.1 Vs a max effort W8 assumeing you can get an aproprite displacement and or valve train for high RPM the hemi will make more power.
Re: Hemi Vs Wedge Debate [Re: HotRodDave] #176863
12/29/08 08:15 AM
12/29/08 08:15 AM
nc
moeflo Offline
moeflo  Offline
nc
I don't think the most jaded wedge fan will attempt an argument regarding flow per area. A well ported 6.1 will have a better flow coefficient than an all out race wedge head. And, thats still an OE casting.
I've been told,and have read how the 426 has this inefficient cumbersome valve train geometry that you just have to live with. I've got a buddy in Ga. who has much quality time with max lift Big Chiefs, Stage V hemis and Sonny's symmetrical heads. He tells me the Stage V had the most trouble free valve train of the bunch. It's noteworthy to mention that the rocker system for the Sonny's head was about the same price as the one for the hemi.
Not an argument to put one over the other. It's just to clear up some misconceptions that seem to follow hemis around.
The question was answered at the start of the thread. Run the one you like.
Re: Hemi Vs Wedge Debate [Re: moeflo] #176864
12/29/08 08:27 AM
12/29/08 08:27 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
A popular misconception about the Hemi is that the valve train is trouble. I know that Pro Stock racer Warren Johnson has been a vocal critic of the Hemi and comments that with pushrods going this way and rocker arms going that way, it's not his idea of a promising configuration. Actually it is an extremely durable valvetrain. You've got alcohol dragsters running 10,500 rpm routinely and the parts last for years and years and years. I've got Stage V Engineering rocker arms on several competitive alcohol cars that are ten years old. I can't think of a better testament to the durability of the double rocker shaft design layout and validity Chrysler's execution.
- Eric Hansen
Re: Hemi Vs Wedge Debate [Re: HotRodDave] #176865
12/29/08 08:37 AM
12/29/08 08:37 AM
nc
moeflo Offline
moeflo  Offline
nc
I do, and the answer is "no way".
Two things other than the economy that are holding up race development of the 6.1. One is, it's not a Chevy. 30 minutes after the first LS motor hit the showroom, K Mart had several aftermarket head castings on the shelf. We're all used to that. Second, a 6.1 flow-wise takes a little more work to improve on than normal. The main weakness is the design and production of high lift valve trains. They will eventually come, but like a good 440 block, it will take a while. In the meantime, we'll keep hearing how a LS Chevy is sooooo amazing, how the LS motor is something revolutionary, etc., etc. But, when pressed, nobody can tell you exactly whats so revolutionary about them. But, we're used to that too.
Stuff like this is why I'm not so big into hemi vs. wedge debates. I'd just like to see what is hands-down the best new line of V8's get a little support in the market. But, being a Mopar guy at heart, I've learned patience. I don't like it, but I've learned it.
Re: Hemi Vs Wedge Debate [Re: moeflo] #176866
12/29/08 09:00 AM
12/29/08 09:00 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Flow rates are for Chevys.Just look at the runners and direct entrance and exit design of a Hemi head,The only way to improve it is to decrease the size of the combustion chamber and get that big dome piston top out of the way.
Re: Hemi Vs Wedge Debate [Re: Ari440] #176867
12/29/08 09:57 AM
12/29/08 09:57 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Amen to that. The 440 was an engine designed for dump trucks and Imperials. The Hemi was specificly designed for racing. That being said the 440 is pretty impressive that it was able to morph into a fairly good street/racing engine. As far as the Hemi/Wedge thing goes the Hemis have some inherient problmes with effciency. The surface to volume ratio is terrible. Very heavy and clumsy piston needed for any kind of compression and an Ardvark valve train with a huge amount of mass. Are they a better power maker? In pure form yes. Soley because of their pumping ability. The "modern" wedges are a much better choice overall though. Back in the day there was no better choice than a Hemi for max power levels or its abilty to deposit more cast iron on the race track in a weekend than any other engine.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Hemi Vs Wedge Debate [Re: moeflo] #176868
12/29/08 10:49 AM
12/29/08 10:49 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Sorry I thought we were talking about 426 hemi heads not new stuff... I was just making a point that the original hemi was BIG, and that's why a 450 cfm port would make less torque down low then the smaller wedge port.
As for new hemi stuff no doubt it's good. But I haven't seen any 400cfm #'s anywhere, 370cfm maybe, but not 400... Who's doing those?
And by the way you're right, I never realized how freakin' big a 302 Boss head was!!! LOL...
Re: Hemi Vs Wedge Debate [Re: Steve1118] #176869
12/29/08 03:57 PM
12/29/08 03:57 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Bob Reed says: "There are two types of people in this world, those who have Hemis and those who want Hemis".
I couldn't say it better myself!
He is wrong...there are acually three types of people....the two you listed and add to that the ones who have blown them up....
71 440-6 4spd & 69 Hemi 4spd
Re: Hemi Vs Wedge Debate [Re: hemi_doug] #176870
12/29/08 04:23 PM
12/29/08 04:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
He is wrong...there are acually three types of people....the two you listed and add to that the ones who have blowen them up....
Been there....spensive...
Re: Hemi Vs Wedge Debate [Re: hemi_doug] #176871
12/29/08 04:49 PM
12/29/08 04:49 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
You know, I've been racing Hemis since the late 60's and had exactly one (1) engine failure. In 1983 a rod broke, bent a couple of valves and busted the block around the pan rail. We sleeved two cylinders, put new valves in two cylinders, welded the block and raced that motor again the next weekend. That motor raced unti 2004, only putting in rings and bearings every couple of years.
Don't give that unreliability crap. I've NEVER had a reliability problem, and I know that BG will tell you exactly the same thing. If someone does, it means they are overrevving it, which is totally unnecessary, or don't know what they are doing.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Hemi Vs Wedge Debate [Re: Dragula] #176872
12/29/08 07:06 PM
12/29/08 07:06 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
So have I...more times then I care to remember...
and blowen = blown....guess I blew that one...
Well Steve, I've lost one rod (stock), Had a valve float and dink a piston (bad spring), and now a valve seat drop out (MP aluminum heads).....So it's not just people over revving or not knowing what they are doing.
Re: Hemi Vs Wedge Debate [Re: hemi_doug] #176873
12/29/08 08:53 PM
12/29/08 08:53 PM
Steve1118 Offline
Steve1118  Offline
You seem to have had more problems than most have.
A stock rod breaking....that is possible, that is why we generally polish and grind the sidebeams. Are you sure a bearing didn't get tight?
As far as a bad spring....that is not even close to being the fault of engine design. Valve float is caused by overrevving it, the wrong spring for the application, or a faulty or worn out part. That is why you keep after that stuff in a race car. Any race car.....any type of engine.
You still are not going to convince me that a Hemi is an unreliable piece, if built and raced correctly. If not, no design will survive. I have forty years of racing them that says you are wrong.
Page 3 of 4 1 2 3 4
