Re: '70 Superbee underhood wiring details
[Re: Quikshft]
#176645
12/29/08 12:54 AM
12/29/08 12:54 AM
Posts: 6,679 Va. Beach, Va
69superbee383
Va. Beach, Va
Looks like a 69 and earlier regulator and harness. Here is a pic of one I pulled from a 70. First pic is the bulkhead connector the reg. plug and wires to the ballast and oil press send.
[Re: 69superbee383]
#176646
12/29/08 12:56 AM
12/29/08 12:56 AM
69superbee383
Va. Beach, Va
here is a pic of the reg plug and ballast wires also can see the oil press wire
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: 69superbee383]
#176647
12/29/08 01:01 AM
12/29/08 01:01 AM
69superbee383
Va. Beach, Va
Go down the engine harness to the alt. connectors. Do you have one or two field wires? If just one dk green would be a 69 and earlier if there are two should be one dk green and one with two blue in one connection thats a 70. Scroll up to my pic with the alternator showing and you can see the blue field wires.
[Re: Quikshft]
#176649
12/29/08 01:18 AM
12/29/08 01:18 AM
69superbee383
Va. Beach, Va
Well the engine harness was around 85 bucks from Year One. Seems someone went to a lot of trouble to change that out.
[Re: Quikshft]
#176651
12/29/08 01:39 AM
12/29/08 01:39 AM
69superbee383
Va. Beach, Va
I think you can still use Moparts 15 and get a 15% discount. They are made by M and H and Year One has the market sewed up on them.
[Re: 69superbee383]
#176652
12/31/08 11:15 AM
12/31/08 11:15 AM
i got a harness from evan's wiring in erie pa. it is perfect and he will gladly tell you where all the wires go. he has a wiring harness to let you use electronic ignition on the older cars also. if you need it i will get his phone number.
