Will a 413 long ram intake physically fit a 71 B Body? #1762784
02/25/15 05:30 PM
02/25/15 05:30 PM
Springfield, MO
Steve88 Offline OP
Steve88  Offline OP
Springfield, MO
I like to do things out of the ordinary and I am considering converting a 413 long ram intake to EFI and using it on my 71 Roadrunner. I did some research and it seems some say they intake will not fit without hitting the shock towers then some say it will. I know there were two versions of the long ram with some being shorter than others so I thought maybe the shorter version would fit but I am hoping someone here onthe board has more info. Thanks!
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: Steve88] #1762785
02/25/15 05:37 PM
02/25/15 05:37 PM
dogdays Offline
dogdays  Offline
The diifference between short and long is that the long rams had the divider all the way and the short rams had the divider missing for some of the length. IIRC they were both the same physical length.
R.
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: Steve88] #1762786
02/25/15 05:46 PM
02/25/15 05:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There B-bodies out there with the long rams, every one I've seen has a box built in the right inner fender for the plenum.
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: dogdays] #1762787
02/25/15 05:48 PM
02/25/15 05:48 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
R.
You are correct. The outside dimensions are the same short and long.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: Digger73] #1762788
02/25/15 07:11 PM
02/25/15 07:11 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yehp outside dimensions the same and it will hit the shock tower if you don't mod it
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: GTX MATT] #1762789
02/25/15 07:53 PM
02/25/15 07:53 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
And also no room for conventional power brake booster.
Re: Will a 413 long ram intake physically fit a 71 B Body? [Re: Steve88] #1762790
02/25/15 09:15 PM
02/25/15 09:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I contemplated doing a long ram in a 71 B body, but after measuring a set for mock up, there's no way without some fender and master cylinder mods, the best way out, esp if your doing a custom EFI set up is to fabricate your own ram manifold using steel tubing, this way you can better manage the layout inside the engine bay
