Re: Big Block Mopar valve cover recomendations
[Re: bigtimeauto]
#1761889
02/24/15 03:22 PM
02/24/15 03:22 PM
Posts: 10,039 MN
JERICOGTX
MN
A friend had a set like pictured for his small block, and took them off right away. The reverse lid holds oil, and he was dripping oil all over his clean engine bay, when taking them off.
Never had a problem with INDY cast covers either.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1761891
02/24/15 03:47 PM
02/24/15 03:47 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Well depending on what rockers and heads he has he might not have a choice.
[Re: bigdad]
#1761894
02/24/15 04:28 PM
02/24/15 04:28 PM
Posts: 43,236 Bend,OR USA
Cab_Burge
I've used Cal Customs, M/T, Mopar and some other cast aluminum covers on a lot of different motors with stock stamp steel, stock ductile iron, Crane extruded alumunim , Harland Sharp rollers to T&D single shaft system with no problems
[Re: Mr.Yuck]
#1761896
02/24/15 04:38 PM
02/24/15 04:38 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
IMOI if you go with a sheet metal cover of any kind I would suggest looking for a billet rail one for sure. Most I have used required clearancing a tad.
[Re: PC-CHARGER]
#1761899
02/24/15 05:24 PM
02/24/15 05:24 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I have the Mancini fabricated covers with HS rockers and RPM heads. Not sure if they would clear the Victor versions though. With Superperformance gaskets, no leaks.
http://www.manciniracing.com/bfaalvacoset.html
There are the ones I am using with Indy EZ's and HS rockers. However I did end up knocking out the baffles....
[Re: max_maniac]
#1761900
02/24/15 07:04 PM
02/24/15 07:04 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Bigdad I have a set of the older Summit cast aluminum vc's. PM me if you are interested.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: bigdad]
#1761902
02/24/15 08:16 PM
02/24/15 08:16 PM
Cab_Burge
Victor heads, Harland Sharp rockers
Too wide
The ones I linked will clear I'm sure, I'd like a cast cover but I don't think any of them are wide enough to clear
I've got a set of Victor M.W. heads on my bracket motor now with Hughes rockers, I'm replacing them with a set of Harland Sharp 1.6 roller rockers as soon as they build and ship them to me I've had two different sets of Valve covers on this motor so far, Cal Custom cast with four breathers on them and the current set of Indy cast covers to use with the new vacume pump. I'll let you know how the Harland Sharps clear the Indy cover in two weeks, hopefully
[Re: ProSport]
#1761904
02/24/15 09:41 PM
02/24/15 09:41 PM
Posts: 34,933 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I called Hughes, ordered a set that should work for now told him to ship them to the machine shop which is about 175 miles away yep .. got the invoice, coming here so, now weather permitting I'll have to drive 340 miles round trip just so we can get it finished and on the dyno by Monday and then I'll need to drive back down again next week why can't people listen ?
