Re: brass soft plugs falling out [Re: mopar dave] #1761378
02/24/15 01:13 AM
02/24/15 01:13 AM
warren, mich.
dwayne welder Offline
warren, mich.
I install all my welch plug's with "JB" Weld!!!! I wire wheel clean the block hole's first, then clean with lacquer thinner, good to go!!!! But Check size of hole in block and size of welch plug for good press!!!! Never take anything for granted, weather new or old!!!!
Re: brass soft plugs falling out [Re: dwayne welder] #1761379
02/24/15 02:19 AM
02/24/15 02:19 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
thanks Dwayne.
Re: brass soft plugs falling out [Re: rowin4] #1761380
02/24/15 04:49 AM
02/24/15 04:49 AM
Washington
skrews Offline
skrews  Offline
Washington
As stated above , soft plugs that come out or start leaking were improperly installed. Most take the easy way and put a socket in the center and pound them in. By doing that, it pulls the sides in and reduces the wall tension. The proper way is tapping the outer cup ring till flush with the block, some sealer might help but most of it will be pushed into the block by the tight fitting soft plug. I have used brass soft plugs on 3 engines and never had a leak or have one pop out.
this
Re: brass soft plugs falling out [Re: skrews] #1761381
02/24/15 08:34 AM
02/24/15 08:34 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i drill 3 small holes at the lip of the block and run weld wire never fell out again
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: brass soft plugs falling out [Re: Ian] #1761382
02/24/15 02:29 PM
02/24/15 02:29 PM
dogdays Offline
dogdays  Offline
Two things:
1. The proper way to drive them is is by pushing on the outer rim. I only found that out a couple of months ago and I've never had an issue driving them in with a socket. But it seems the "right" way is by the outer rim.
2. Cup plugs come in two styles, deep and short or something like that. So there are two distinct plugs for every diameter. I think which one you use depends on the depth of the hole.
R.
I used "the right stuff" on my last job.
Re: brass soft plugs falling out [Re: dogdays] #1761383
02/24/15 11:29 PM
02/24/15 11:29 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I use my snapon installer tools. It comes in many sizes. Never had a failure. Brings them up flush. No sealer, just clean parts.
Re: brass soft plugs falling out [Re: dogdays] #1761384
02/24/15 11:53 PM
02/24/15 11:53 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I was told that freeze/soft plugs have a slight tapper to them and when you put them in with a socket that is take's the tapper away.
So when I first started working on car's for a living the snap on tool was one of the first I bought.
