Re: Front end limiters?
[Re: RV2]
#1760914
02/23/15 10:52 AM
02/23/15 10:52 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What ever you choose to use, be sure it is progressive in nature so as not to shock the chassis when the limit is hit. Any solid type stop will try to unload the rear tires when a sudden stop of front end travel occurs if there is still a load on the front tires. You can't see the end, but that eye bolt goes through the upper A arm and uses shock absorber rubber biscuits to cushion the stop.
