Cam Thoughts #1760792
02/22/15 09:08 PM
02/22/15 09:08 PM
MD
ADakotaRTGuy Offline OP
MD
Might be thinking the cam is not optimal.
It is a 440 Small block with W9 heads, 4.125 bore and stroke. 727 trans with 3.92 rear gears. 9:1 compression. Heads are being redone and flow should increase a bit.
Head flow numbers are
.100"--76.5/N/A
.200"--145.0/113.1
.300"--204.8/167.6
.400"--261.1/215.7
.450"--283.3/227.9
.500"--306.8/236.1
.550"--319.4/240.9
.600"--337.4/245.3
.650"--348.2/248.4
.700"--353.1/251.2
255 / 263 @.050 668 / 668 lift on a 110. Calculates out to be 39 degree overlap.
Re: Cam Thoughts [Re: ADakotaRTGuy] #1760793
02/22/15 09:26 PM
02/22/15 09:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if the rpms are ok for you now or if you
want some more.. but the lift needs about .080- .100
more for your heads.. and I assume you will spray it
now and then
Re: Cam Thoughts [Re: MR_P_BODY] #1760794
02/22/15 09:39 PM
02/22/15 09:39 PM
MD
MD
now and then
I was shifting at about 7k before, but I think that was to high, should have probably taken it to 6k.
Should it have more overlap?
Re: Cam Thoughts [Re: ADakotaRTGuy] #1760795
02/22/15 09:44 PM
02/22/15 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
now and then
Not if you spray once in a while
