Broadcast sheet question #175630
12/26/08 08:54 PM
12/26/08 08:54 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
What is trans code 34... 727 or 904 ?...engine is E55 (340)...thanks
Semper Fi
Re: Broadcast sheet question [Re: GOLDMYN] #175631
12/26/08 09:14 PM
12/26/08 09:14 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Look here-- mymopar.com
Re: Broadcast sheet question [Re: GOLDMYN] #175632
12/26/08 09:58 PM
12/26/08 09:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
D34 indicates H.D. automatic transmission in '72-'73.
I don't think Chrysler Corp. put 904s behind 340s ... ever.
LINE 4 of b'cast should show:
- 843 under TRANS for 3515843 early '72
or
- 052 under TRANS for 3681052 late '72 & 1973
Re: Broadcast sheet question [Re: 6bblgt] #175633
12/26/08 10:21 PM
12/26/08 10:21 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
thank-you, that a spot of the sheet that has a hole in it
Semper Fi
Re: Broadcast sheet question [Re: GOLDMYN] #175634
12/26/08 10:25 PM
12/26/08 10:25 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
broadcast sheet
Semper Fi
Re: Broadcast sheet question [Re: GOLDMYN] #175635
12/26/08 10:35 PM
12/26/08 10:35 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
No 904s behind 340s from the factory so it would be 727.
