need help asap please.car olny sparks when turn key off
#175565
12/26/08 07:57 PM
12/26/08 07:57 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
buddy has a 71 charger that ran fine with the factory points (small block) then one day his wife drove it to work and came out ..nothen so brung it home thinking the points burnt up so now is good time to upgrade to eletronic. so bought a conversion droped it in still no start so bought a new coil still no start got a couple of differnt digrams and evert thing is hooked up right but the only time it will spark is when you turn the key off and its just a one time spark till next time turn it off have a 73 car that runs fine and checked the power to both sides of the coil both with key in run and start and the exact as the one that wont run so what the heck is the deal box is grounded even swaped the box off the running car still nothen why is it only getting a spark from the coil when turn the key off thanks in advance guys
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: need help asap please.car olny sparks when turn key off
[Re: toplescuda]
#175567
12/26/08 08:03 PM
12/26/08 08:03 PM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
maybe ballast resistor or ignition switch. will it fire if you jump the starter relay?
[Re: JeffC]
#175568
12/26/08 08:12 PM
12/26/08 08:12 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
car cranks over fine and the ballist is good it just dont spark from any time you turn the key on(even cranking) till you turn the key to the off postion then it has one nice spark
[Re: groundpoint6]
#175571
12/26/08 09:02 PM
12/26/08 09:02 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
The box is gone !! Sorry reread your first post , As the above poster said , looks like the pick up coil in the dist is not working or the gap is too wide to trip the ECM which in turn unloads the coil
[Re: mopar_man]
#175572
12/26/08 09:37 PM
12/26/08 09:37 PM
Posts: 2 Taylor MI
spl151
Taylor MI
Yep thats the problem had it happen to me!
[Re: IronWolf]
#175574
12/26/08 10:16 PM
12/26/08 10:16 PM
RapidRobert
set the reluctor gap to .008". key on coil wire 1/4" from ground & jump coil neg to ground & make & break it. if the 73 is a SB borrow it's dist
[Re: NITROUSN]
#175576
12/26/08 10:27 PM
12/26/08 10:27 PM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
You most likely could be fighting the original problem. The car did not run with points so maybe the problem is in the ignition switch or wiring. It may not have anything to do with the conversion.
bad idea to assume the points were bad and do a conversion without confirming the original problem, because now you don't really know what the original problem was...
start there, and good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: bigblock4x4]
#175581
12/27/08 02:11 AM
12/27/08 02:11 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
My add to this problem is that I had a bad wire in the ignition harness where it plugged in to the the switch. Another possible problem is a bad connector in the firewall bulkhead connector for the ignition run switch. Also the ignition switch itself could be bad.
[Re: sthemi]
#175582
12/27/08 10:04 AM
12/27/08 10:04 AM
Posts: 518 COLLINGWOOD, ONT
71_deputy
COLLINGWOOD, ONT
i agree- the orginal problem- as you turn off the ing. key there is enough connection to give spark!
