69 RoadRunner Dash Help #175488
12/26/08 06:28 PM
12/26/08 06:28 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
On a 69 RR how far does the long swith panel bezel go into the soft bottom dash trim? I have just got it started and it is stuck just inside the edge and I think it needs to go farther in. A 1 3/4" screw won't start where it is. Thanks Ronnie
Re: 69 RoadRunner Dash Help [Re: okie] #175489
12/26/08 06:36 PM
12/26/08 06:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It bolts solid to the dash frame so that tells you how far it needs to go. The column shold be dropped and the lower padded dash real loose so it will slide in place.
Re: 69 RoadRunner Dash Help [Re: NITROUSN] #175490
12/26/08 07:12 PM
12/26/08 07:12 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
They use to just slid into place, but after 40 years the padding and vinyl get a little harder and smaller, making the fit a lot tighter.
Anyhow, try to soften up the vinyl pad with some good dressing and maybe a hairdryer to warm it up a bit..
Re: 69 RoadRunner Dash Help [Re: sthemi] #175491
12/26/08 07:31 PM
12/26/08 07:31 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The thing that might be hanging it up is the thumbwheel for the dash lights. All the switches are a fairly tight fit, but as I recall the thumbwheel cage is the worst.
Re: 69 RoadRunner Dash Help [Re: topside] #175492
12/26/08 10:49 PM
12/26/08 10:49 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Yep, I just argued with this last weekend.
Left the lower pad loose, took out the dimmer and headlight switch then wiped the outer part of the panel with sillycone spray on a rag. Went in pretty easy. Putting the switches back in was a bit slow but do-able.
I can't afford this. mark
