Re: Setting timing to max vacuum
[Re: SomeCarGuy]
#1754439
04/03/15 01:51 PM
04/03/15 01:51 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If it all starts again - check the chain. It will take less than 5 minutes and you only have to remove the distributor cap so you can see the rotor.
[Re: SomeCarGuy]
#1754440
04/03/15 05:00 PM
04/03/15 05:00 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
The petronix kit is very sensitive to voltage. Be double sure you have a solid connection feeding it HOT. That is critical to know when setting one up.
I second the call to check the chain. The nylon might be causing some weird timing events on occasion.
I also agree a funky set if plugs could be derailing you. Ngk is good and ive had good luck with densos as well.
What part number of NGK would you recommend for this engine
