TRANSMISSION CROSS MEMBER #175418
12/26/08 04:16 PM
12/26/08 04:16 PM
Sweden
Mopar Guy Offline OP
Sweden
Can any one tell me what a 1973 Charger use for trans cross member for bb & sb and if there is any differens on auto or 4-speed trans.
Pleas contakt me by mr440mopar@hotmail.com
Thanks for any help i can get in this qestion !
/Patrik
Re: TRANSMISSION CROSS MEMBER [Re: Mopar Guy] #175419
12/26/08 10:29 PM
12/26/08 10:29 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
I can tell you this, I converted a 74 charger 318 auto to a 340 stick and the same cross member worked for both transmissions. I do believe that big and small block are the same BUT am not 100% sure. Hope this little bit helps.
Re: TRANSMISSION CROSS MEMBER [Re: 340cpe] #175420
12/27/08 03:59 AM
12/27/08 03:59 AM
Sweden
Sweden
Ok that whas some help Thanks and i know that the B and E-Body share the same cross member 1973-74 so if any one else know´s any more in this matter pleas do tell me and id realy like to know if the sb and bb use the same cross member also and if any ohter car´s use this cross member as i will need one !? Just so i know what i have to look for !
