Front strut Bushings--Installing #175402
12/26/08 03:15 PM
12/26/08 03:15 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Anyone install the NEW style front strut bushings on your car these are one piece rubber goes around strut and sits in lower control arm hole--Or did someone take me for a ride on these got them from a Dodge dealer-I can't seem to get them to fit???? Thanks
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Front strut Bushings--Installing [Re: swifter] #175403
12/26/08 03:19 PM
12/26/08 03:19 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I use them sometimes, I use a propane torch to burn whats left out. The spray wd-40 or PB-blaster on them and install. As you tighten the bolt they will pop in the hole there selves.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Front strut Bushings--Installing [Re: 70dart360] #175404
12/26/08 08:57 PM
12/26/08 08:57 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Spray some silcone on them and tap them in from the back side with a hammer handle.
