Re: Dropping an FJM subframe?
[Re: Dblt68]
#175307
12/26/08 11:19 AM
12/26/08 11:19 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, I owned an M for years, but never did that.
Did drop the K member on a 79 B body, similar isolated design. You had to unbolt the arms on that one, not sure if this helps you though.
[Re: mopowergtx]
#175309
12/26/08 02:37 PM
12/26/08 02:37 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Yep you definitely need to pull the control arms. They wont clear the frame at all. You also need to pull at least one of the shock and control arm brackets as well because those go over the rails as well. If you pull em both, then the thing slides straight down. I've pulled a bunch myself as well .
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: Dblt68]
#175312
12/26/08 11:45 PM
12/26/08 11:45 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
If you can ..get the steering colume also..its most likley better than the one in your car .err What are you putting it in ??...Mine is in my 1956 Plymouth and was the best and easiest install..car rides great and straight ,and stops nicley with the disc brakes..take the master cyinder and porportion valve also.. the hardest thing for me were the motor mounts for the 440.good luck
