Re: 46RH behind a 5.9 Cummins in my Ramcharger
[Re: Moparnut426]
#1747809
02/06/15 02:48 PM
02/06/15 02:48 PM
Posts: 760 Canada
CTD5.9
Canada
[Re: CTD5.9]
#1747810
02/06/15 03:09 PM
02/06/15 03:09 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
A 46 won't bolt up. Are you considering a non lockup 518 or a lockup 47?
[Re: Moparnut426]
#1747812
02/06/15 05:17 PM
02/06/15 05:17 PM
Guitar Jones
In that case it should be OK, you will probably need to redrill some if not all the crossmember mounting holes. The shaft will need to be shorter so you may want to consider bigger u joints. What rear are going to put in it?
EDIT: You might also change out the O/D guts, except for the output shaft from the diesel trans as it should have better planetaries and possibly more clutches.
[Re: Guitar Jones]
#1747813
02/06/15 05:47 PM
02/06/15 05:47 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
The diesel tranny I have has all the guts ill need, just gonna need the case for the OD, as for the rearend and front end, I plan on a 70 rear, and a 60 front, but I don't want to use 8 bolt wheels cause my wheels and tires are new, so I found a company that sells a different knuckle to run the 5 bolt stuff. I will just make a 70 work with 5 bolt axles at the rear also. Honestly just throwing this around as I dono If I really want to pull the 440 sixpack that's in the truck out just yet.
[Re: Moparnut426]
#1747814
02/06/15 05:52 PM
02/06/15 05:52 PM
Guitar Jones
The 70 has floaters, I know of no 5 lug hubs and drums for that.
