2002 DODGE NEON OEM air intake tube ? #174767
12/25/08 12:52 PM
12/25/08 12:52 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
The one I have on the wifes Neon has cracks in it causing the motor to rev when stopped or put into park. I had the sensors checked and simply need this tube. My problem is that I can not find the name of the tube. I have searched all over the net and came up with squat. My question is simply what is it called and where can I get one.
Thanks a bunch everyone and Merry Christmas.
Re: 2002 DODGE NEON OEM air intake tube ? [Re: DEMONIC] #174768
12/25/08 02:11 PM
12/25/08 02:11 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
btt
Re: 2002 DODGE NEON OEM air intake tube ? [Re: DEMONIC] #174769
12/25/08 02:27 PM
12/25/08 02:27 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I'll check tomorrow I think I have a new one under my bench at work. Throttle body to air cleaner hose right?
Re: 2002 DODGE NEON OEM air intake tube ? [Re: SALEM1912] #174770
12/25/08 02:31 PM
12/25/08 02:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
No it's the throttle body to intake piece. Cracks causing a huge vac leak.
Re: 2002 DODGE NEON OEM air intake tube ? [Re: SALEM1912] #174771
12/25/08 02:57 PM
12/25/08 02:57 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
Its the acordian style hose from aircleaner to throddle body.
Re: 2002 DODGE NEON OEM air intake tube ? [Re: DEMONIC] #174772
12/25/08 02:59 PM
12/25/08 02:59 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Right, I'll check T-body to intake.
Re: 2002 DODGE NEON OEM air intake tube ? [Re: SALEM1912] #174773
12/26/08 12:15 PM
12/26/08 12:15 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Chris can't find the one I had .#4669783ac list for about$73
