Re: Hydraulic Roller Cam wear
[Re: TheOtherDodge]
#1745246
02/02/15 11:15 PM
02/02/15 11:15 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Unless you can see something in person that is not showing up in the pic then run it. That is how they all look. If you can not feel any wear on it and it is just the line in the middle that is how they look. I have seen pits on the top of the lobe but there is usually a wide wear pattern to match. Also there is not much sludge in there, usually the worn ones have a bunch of sludge.
[Re: TheOtherDodge]
#1745248
02/02/15 11:33 PM
02/02/15 11:33 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
it is just lack of oil change and a lot of miles run on it. Like Dave said, if you can't feel any wear on it just run it.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: dogdays]
#1745251
02/03/15 01:56 PM
02/03/15 01:56 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Yeah, that brown stuff is varnish. It's a very interesting subject in its own right.
R.
Please elaborate!
[Re: TheOtherDodge]
#1745252
02/03/15 03:07 PM
02/03/15 03:07 PM
dogdays
Varnish has only recently been studied with any level of intensity. This was caused IMHO by the change from Type I base stock to Type II base stock. The Type II oils are more refined and they contain far fewer solvent-type molecules. As a result, Type II oils have more tendency to leave varnish deposits.
What is varnish? It seems to be extremely fine particles of oxidation products. These oxidation products are formed when something acts as a catalyst to the oxidation reaction. Often times it is water that catalyzes the reaction.
Varnish can be filtered out of oil with special varnish collecting filters, or removed by electrostatic filters. Varnish becomes more soluble at higher temperatures, so varnish will collect faster in the cooler spots of the engine. New batches of hydraulic oils that come from the suppliers tend to be Type II oils. As these replace the Type I oils, we have noticed varnish problems, specifically in hydraulic systems where the valves will stick. A short term solution is carb cleaner, which I used to de-varnish the inside of a block I was rebuilding. This block was from my personal car and had had regular oil changes, yet was covered with varnish.
I don't know exactly how to deal with varnish in an engine, most of my work involves either huge journal bearings or hydraulic systems. In those we can use a "kidney loop" filter system with special varnish-collecting media.
R.
[Re: TheOtherDodge]
#1745255
02/03/15 05:05 PM
02/03/15 05:05 PM
HotRodDave
Kalispell Mt.
I would not disturb any of it. If it is stuck down it is not going anywhere, if you mess with it than it will come loose and go through the oil system. That engine looks real good, low miles and typical of a magnum with reasonable maintanence.
