Re: Remove E-Body Steering Column
[Re: Steve Bryant]
#1743490
01/31/15 11:28 PM
01/31/15 11:28 PM
Posts: 199 NC
1970A66
NC
You need to remove the roll pin that goes thru this coupler: http://www.ebay.com/itm/Mopar-B-E-Body-P...e1d&vxp=mtrIn the pic you can see the 2 holes in the right side of the coupler. That is where the roll pin is. Once the pin is removed, the coupler may have to be pried off the gear box splined shaft.
[Re: 1970A66]
#1743491
02/01/15 03:23 AM
02/01/15 03:23 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Here is another picture. The pin in the left center is what has to be removed. This pic is from GTX so the components may differ slightly but it is the same idea Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Steve Bryant]
#1743494
02/01/15 12:55 PM
02/01/15 12:55 PM
Posts: 199 NC
1970A66
NC
I put a Stage II box in my Challenger and love it. If you have Saginaw power steering I strongly recommend this free and easy mod to reduce power steering pump pressure. This mod along with the Stage II box will give you close to a modern car feel of the road, providing everything underneath is tight with the steering and suspension. http://www.moparaction.com/Tech/beep/PUMP_IT_DOWN-re-v1.4.pdfAs I recall I installed 1/8 thick stack of washers, I'm thinking about adding more.
