Re: Tic toc tach accuracy
[Re: Edahlke]
#1743435
01/31/15 07:54 PM
01/31/15 07:54 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Are U running a stepup electronic ignition box? If yes, the OE Mopar tach will not read accurately.. Just my $0.02...
[Re: 6PakBee]
#1743437
01/31/15 11:33 PM
01/31/15 11:33 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Just my $0.02...
What is a electronic ignition? Mopar electronic? Pertronix? MSD? All of the above? ?????
All of the above... Beyond a standard points system..
Just my $0.02..
[Re: Edahlke]
#1743438
01/31/15 11:49 PM
01/31/15 11:49 PM
Posts: 199 NC
1970A66
NC
The tach will work fine with Mopar electronic ignition. It does on my 70 Challenger. Those factory tach circuit boards are NOT accurate. Also the tach needle is press fit on and should read zero with the ignition key off. Your tach has 2 parts: 1)the meter movement and 2) the circuit board. Either one could cause your problem. This is the best option for new circuit boards: http://rt-eng.com/rte/index.php/Main_PageThere are 2 67-74 boards. The more expensive has an on-board calibrator ckt. Is your needle on zero with the car shut off? If so then I think your board is most likely bad. They have capacitors that often fail. But it could be a dirty/sticking meter movement causing the needle to remain on zero until you rev it to get it un-stuck.
[Re: Edahlke]
#1743439
01/31/15 11:55 PM
01/31/15 11:55 PM
Posts: 199 NC
1970A66
NC
[Re: 1970A66]
#1743440
02/01/15 03:17 AM
02/01/15 03:17 AM
Posts: 1,822 Colorado
denfireguy
Colorado
http://www.forbbodiesonly.com/moparforum/showthread.php?61170-Factory-Tach-with-Electronic-Ignition
There is some confusion in that thread and it stems from the different types of electronic ignitions. Mopars ignition system using the black box, orange box, chrome box, etc. uses a reluctor to replace point signaling and a large transistor switch to ground the coil to start the spark sequence. As a result, the switching voltages are the same as the old points system so there is no difference in tach signals. MSD, Mallory and others are what use to be called capacitive discharge systems. They use an inverter to generate around 400 volts to discharge through the coil with a charged capacitor and attaching a tach without the adaptor will destroy the factory tach. IF it did not destroy the tach, it would also be inaccurate as most of them employ multi-spark events on each plug firing at low speeds to insure fuel burn. The adaptor for the tach solves both of those issues. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1743441
02/02/15 05:33 PM
02/02/15 05:33 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Incorrect... An OE Mopar tach (up to 71) will not read accurately with a Mopar electronic ignition, electronic distributor w/orange, chrome or gold box. The tach will indicate some RPM level but it is not accurate.
Regarding other aftermarket systems, Mallory, Pertronix, MSD U better check with the respective manufacturer about compatibility with the various tachs be it OE or aftermarket.. As some external dongle adapter may be required.
Just my $0.02..
[Re: Sinitro]
#1743442
02/03/15 12:16 PM
02/03/15 12:16 PM
denfireguy
Colorado
My mistake not addressing accuracy. I was only talking about the proper voltages and damage to the tach itself. Just to clarify, the voltages present with capacitive discharge systems are too high for factory tachometers to handle and will result in permanent damage. Conventional Mopar systems, points or electronic, will not damage the tach. It still may not read right as the wave forms are not what the tach expected. Dwell on points systems was usually much longer and adjustable. On electronic systems, while somewhat adjustable by adjusting reluctor gap, it is much shorter and presents a different duty cycle to the tach than it was expecting. Craig
[Re: denfireguy]
#1743443
02/03/15 01:31 PM
02/03/15 01:31 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
OK, for those of us running the Mopar electronic distributor and orange box, can you make the factory tach read accurately?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1743444
02/03/15 05:03 PM
02/03/15 05:03 PM
Posts: 5,447 So Cal
Sinitro
So Cal
No... On my 70RR, I swapped out the Tic/Tac for a tach using the VDO insides from RedLine. RedLine custom makes a front plate using the same fonts as the OE Mopar so it matches the other guages. My ignition system is the Mopar electronic distributor and chrome box. I also have run an MSD box without issues except the tach is driven from the MSD box rather than the coil.
Just my $0.02...
[Re: DPelletier]
#1743446
02/03/15 08:04 PM
02/03/15 08:04 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Just my $0.02...
Thanks but I already paid $425 for the tach from Charger Specialties (plus duty, shipping and exchange so probably really about $750.00). I can't see ripping it apart and paying another $300 - $400 so I guess I'll just go by ear for now. ....maybe a hidden rev limiter for safety..
Dave.. The tachs from Charger Specialties have later internal electronics in them, so they are compatible with the older point systems, Mopar electronic systems, MSD and most aftermarket ignition systems.
Just my $0.02...
[Re: Sinitro]
#1743447
02/03/15 09:40 PM
02/03/15 09:40 PM
DPelletier
Just my $0.02...
Just my $0.02...
Thanks, I was wondering about it's accuracy and I ASSuMEd that it was an accurate repop of the originals...I'll maybe check it with a friends spare from his racecar but sounds like I may be good to go!
1974 'Cuda
[Re: 1970A66]
#1743450
02/04/15 01:17 AM
02/04/15 01:17 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Either one could cause your problem. This is the best option for new circuit boards: http://rt-eng.com/rte/index.php/Main_Page There are 2 67-74 boards. The more expensive has an on-board calibrator ckt.
this is awesome! I didn't even know about these guys! now I know where to buy the stuff when I have problems - props to you!
[Re: Edahlke]
#1839949
06/02/15 07:44 PM
06/02/15 07:44 PM
DPelletier
Well to update; my Charger Specialties tach is apparently NFG. they used some sort of composite/graphite body when I bought mine and there are grounding issues. I bought the tach probably 8 years ago but the car has less than 20 miles on it...didn't last long!
Sooooo, I can rip it out, take it apart and attempt to add proper ground wires.....or I can buy a new one somewhere and replace it......or I can give up and bolt a tach to the steering column like people used to do back in 1969.
1974 'Cuda
[Re: Edahlke]
#1840198
06/03/15 12:51 AM
06/03/15 12:51 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Not to hijack but............is there a fix for the tach in my AAR readign roughly double the RPMS. I'm running and undercap conversion from Accel, essentially a Unilite module. Been running it for 7k+ miles now, no damage just double.
Thanks in advance, Kevin
Careful, your character's showing!
