Smartphone wheel-alignment apps #1743315
01/31/15 06:26 PM
01/31/15 06:26 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
For my iPhone, I've downloaded the alignment-app 'iAlign' some time ago already, but today I stumbled on another alignment-app called 'CamberMeas'.
What prompted me to get this app as well was the fact you can enter your steeringbox-ratio, and then just turn the steeringwheel 1 turn to the left, measure, and once to the right to get to the final caster-setting per wheel.
Like iAlign, it also still has the option to turn the wheels 20 degrees left & right to measure/calculate caster, but I thought just turning the steeringwheel one complete turn was a bit simpler.
For having the Borgeson steeringbox in my car, I adjusted it for 14:1 ratio.
Now I really like to get the car aligned on a proper alignment-rack to verify the numbers.
(The numbers in the screenshot, besides showing a different caster-alignment, aren't quite right as I found later I didn't calibrate the app properly at first.)
CamberMeas screenshots
resp. Left & Right tire;
Re: Smartphone wheel-alignment apps [Re: BigBlockMopar] #1743316
02/01/15 09:04 AM
02/01/15 09:04 AM
Queensland Australia
V8val Offline
V8val  Offline
Thanks for the heads up, will be using this for sure!
Re: Smartphone wheel-alignment apps [Re: V8val] #1743317
02/01/15 10:25 AM
02/01/15 10:25 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Now Thats some cool info there. Thank you for sharing
Re: Smartphone wheel-alignment apps [Re: johnscudashop] #1743318
02/01/15 12:40 PM
02/01/15 12:40 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
So do you attach the phone to the wheel somehow?
Re: Smartphone wheel-alignment apps [Re: bordin34] #1743319
02/01/15 01:16 PM
02/01/15 01:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
and which wheel, there's 5?
Re: Smartphone wheel-alignment apps [Re: jcc] #1743320
02/01/15 02:52 PM
02/01/15 02:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looked for one for Android, not really one there that I found.
Don't be the exception.
Re: Smartphone wheel-alignment apps [Re: Supercuda] #1743321
02/01/15 03:12 PM
02/01/15 03:12 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
There isn't. I picked up an angle finder app to get it somewhere decently close.
Re: Smartphone wheel-alignment apps [Re: jcc] #1743322
02/01/15 03:19 PM
02/01/15 03:19 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
6 if you're carrying a spare...
2 Demons...no, not my kids!
Re: Smartphone wheel-alignment apps [Re: MuuMuu101] #1743323
02/01/15 04:33 PM
02/01/15 04:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have two digital protractors for that.
Re: Smartphone wheel-alignment apps [Re: Supercuda] #1743324
02/01/15 04:43 PM
02/01/15 04:43 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I don't.
Re: Smartphone wheel-alignment apps [Re: MuuMuu101] #1743325
02/01/15 04:47 PM
02/01/15 04:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I bought them long before I ever had a smart phone, today I would just use the smart phone app, I have at least two of them so it'd work fine for me. Heck, I even have a dedicated garage laptop.
Re: Smartphone wheel-alignment apps [Re: bordin34] #1743326
02/01/15 07:25 PM
02/01/15 07:25 PM
The Netherlands
The Netherlands
The phone doesn't necessarily has to be mounted against the wheel at all times. You can hold it against the wheel, take a measurement and move on.
My wheels happen to have a nice flat spot in the center so it's very easy to hold the phone against it.
For camber-adjustments it would be nice to fix the phone on the wheel while adjusting.
For caster-adjustments you need to keep one of the phone's axis as good as vertical, while holding the right side of the phone against the wheel for the measurement. So a fixed phone could work as long as you can reposition it upright after turning the wheel.
