Re: Broadcast Sheets - L&F B Body
#1742
01/13/08 11:14 PM
01/13/08 11:14 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
missing build sheet for my 68 Road Runner - RM218G156648. Any help is appreciated. Missing the original block as well. chris_kalisz@boxco1.com
[Re: 440PURSUIT]
#1743
01/18/08 11:45 AM
01/18/08 11:45 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Looking for my broadcast sheet. 1968 Hemi roadrunner. RM21J8G119670 Also missing the original block and trans. Block should have the following numbers 8G119670. This stamping is located at the back of the engine where the bellhousing would bolt into the block at the 12 o'clock position. Please note there is no machined pad like the 1969 and up engines, just the numbers on the rough cast surface. The numbers 8G119670 also should be on the machined pad located on the transmission domingo426@gmail.com
[Re: moparts]
#1746
01/31/08 01:26 PM
01/31/08 01:26 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Broadcast sheet wanted for my 70 6 Barrel Roadrunner RM23V0G147353. Thanks. tbjts@verizon.net
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
[Re: PDFrogman]
#1748
02/18/08 08:42 PM
02/18/08 08:42 PM
Posts: 191 Vernon, NJ
PDFrogman
Vernon, NJ
still looking for my missing fender tag and build sheet for my 1969 Plymouth sport satellite convert 383 automatic, console, B5 blue, white top white gut. Vin# RP27H9G245278 last registered in NJ I bought it mid restoration need info to restor correctly car was last registered in freehold NJ area email pdfrogman@aol.comThanks...
GTX Sheet
[Re: PDFrogman]
#1749
02/21/08 01:38 PM
02/21/08 01:38 PM
Posts: 1,106 CANADA
Desmond
CANADA
Broadcast sheet for 1970 Hemi GTX - help me find it: RS23R0A172870 somebody has this - a photocopy of the original was sent to Galen Govier a few year's back - came from Florida. Kept the original for themselves.
FOUND: 73 Charger Broadcast in 73 Satellite
[Re: Desmond]
#1750
02/23/08 11:54 PM
02/23/08 11:54 PM
Posts: 2,886 US of A
A38s!
US of A
Found 73 Charger 400 sheet 3/4 intact: wp29m3g165543 Under carpet of 73 Satellite 400 9-passenger: rh46m3g163844. Build Date Jan 16, 1973. 1,699 sequence diff, St L plant. Thanks Moparts!
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
[Re: moparts]
#1754
03/16/08 01:10 PM
03/16/08 01:10 PM
I have a fender tag from a 68 Road Runner I used to own. I found it in some old paper work. The s/n is 2948XX If you can comeplete the S/N correctly, I'll ship the fender tag for free! Keith
[Re: Alaskan_TA]
#1755
04/09/08 07:16 AM
04/09/08 07:16 AM
Posts: 3,427 PA
PLATINUM6BBL
PA
XS23UOG161504 is free to owner with proof of ownership
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: Old_Moparz]
#1756
04/27/08 12:26 AM
04/27/08 12:26 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Looking for build sheet or original engine for my 1970 Charger RT XS29UOG203165. The car spent alot of time in the Tulsa Oklahoma area. The car was originally FE5 red with a black top. If you think you may have info. about my car PM me or email me at Blakcharger440@sbcglobal.net.
