Re: Dodge SRT4 kicks butt in Ultimate Street Car event
[Re: Lefty]
#1742778
01/31/15 12:25 AM
01/31/15 12:25 AM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
He is going to sell his f, um, camaro, ya that's it, camaro.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1742779
01/31/15 01:48 AM
01/31/15 01:48 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
At least the loser was appreciative.
[Re: MuuMuu101]
#1742781
02/02/15 12:57 AM
02/02/15 12:57 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I'm not going to lie... But that's one of my drivetrain options I've been thinking about for the Dart. Maybe not as crazy as 600 hp though.
it wouldn't be a completely crazy idea, I can only imagine how little that engine weighs -
[Re: dangina]
#1742782
02/02/15 01:00 AM
02/02/15 01:00 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
About 250 lbs from my research... I'm not sure if that includes a turbo but add a 100 lbs for the turbo, tubing, intercooler, and accessories. There are a couple people who have bolted it up to a Chevy MA5 with a Jeep Liberty bellhousing. They have adapter plates to bolt it to a small block transmission so I wonder if it would be compatible with a T56.
[Re: MuuMuu101]
#1742783
02/02/15 01:55 AM
02/02/15 01:55 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
What's the SRT-4 weigh? Back in the day I figured the IROC R/T Daytona motor would be a lot of fun in an A-body, so why not an SRT-4 setup? Good mileage, great power, classic styling...wrong sound!
2 Demons...no, not my kids!
[Re: 4speeds4me]
#1742784
02/02/15 02:20 AM
02/02/15 02:20 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
SRT4 weighs about 2900 lbs. So essentially my Dart would be a 6-speed rear wheel drive SRT4 that might be a touch lighter and better looking. The reasons you presented are all reasons as to why I'm thinking about doing it. The sound can be fixed or toned down though.
[Re: Trojmn]
#1742786
02/02/15 03:38 AM
02/02/15 03:38 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
they made 25000 SRT4s and tens of thousands more turbo PT cruisers all the way to 2009. its a much better motor (parts wise) than a turbo III.
The SRT4 engine weighs more than you think. closer to 350 with manifolds/accessories and it is tall. Then you also need intercooler, piping, etc... There are a couple people working on A-body swaps right now, i kicked it around half halfheartedly as well. The issue that i can see is that a good street able e85/stage3 turbo will do 400ft and 400HP. you can do that with a MILD v8 all day. and not have as much torque right off idle to 2500. 3000 on up it will run great.
In the end it would be a giant PITA. cool but a pain. I'm going 5.7 hemi as soon as i can stand to have my car out of commission... which is why the engine is still on the stand for 4 years.
People are having troubles with the SRT4 head in a RWD configuration as it positions the intake and exhaust manifolds in the wrong directions. Some people are going with a 420A head as it flips the direction and uses the same mounting pattern while others are making custom manifolds. I know of 3-4 projects on FABO that are doing the swap. About 350 whp and torque would be my goal, but I want to run it on 91 octane.
Gen III Hemi is a really cool swap but I just don't like how everything is so tight in the engine bay. I like the uniqueness of the SRT4 swap and how open it is. It will give you a little more room to work, be a little cleaner, and you can add more to it.
Either way, I'd like a T56 in the car so with a small block bellhousing or Gen III bellhousing I have 3 different engine options. But, like you said, it's just a half hearted idea till I get my Dart running on all 4's again. I'd definitely want a more fun daily driver or another "toy" car the next time the Dart goes out of commission.
Some build threads:
http://www.forabodiesonly.com/mopar/showthread.php?t=158780
http://www.forabodiesonly.com/mopar/showthread.php?t=218144
http://www.forabodiesonly.com/mopar/showthread.php?t=157546
[Re: prrc]
#1742789
02/25/15 02:14 AM
02/25/15 02:14 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
SRT4 swaps, there are a lot of people that have done this with Fox Body Mustangs, Dodge Colts, on and on, we like doing it with the first generation Neons. We are building a 96 Neon with SRT4 motor swap, SRT Neon Brake Swap, plug and play stage 3 Turbo with toys, NDETCS traction control and anti lag, Srt Trans with billet components, Rota Slipstream Wheels. Car should weigh in at 2400lbs and easily make 385 WHP. Should run somewhere around 11.00s on slicks with open exhaust. Nothing like having a lot of fun on the street with a car that looks like just a small two door driver that just does not go fast. We also have a 2004 SRT4 Neon all stock and an 2005 SRT4 Neon with some toys for fun. The 1996 Neon is being built for a class called Time Tech. So do the SRT4 swap, it is not all about the easy was to do things. Take a look at this Colt that has an SRT4 Swap running rear wheel drive. Looks like he has no problem with making it run or fit. https://www.youtube.com/watch?v=hreTfjYMPA0
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#1742790
02/25/15 02:17 AM
02/25/15 02:17 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
See, I was thinking about that recently. An SRT4 swap in a Neon coupe would be faster and much more of a sleeper than if it was in my Dart. However, my Dart would have larger tires and brakes to better handle the power. The weight distribution may be a bit better too.
[Re: MuuMuu101]
#1742791
02/25/15 03:09 AM
02/25/15 03:09 AM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
