What size headers tubes on your B1 combo's
#1741816
01/29/15 07:45 PM
01/29/15 07:45 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
B1 heads only please but I am soon going to be having a set of headers made for my B1 headed 572. Probably going to be a stepped header type design but what are you guys running. This will be for a nitrous combo. Thanks
Re: What size headers tubes on your B1 combo's
[Re: pittsburghracer]
#1741818
01/29/15 08:18 PM
01/29/15 08:18 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
My 525 junker is 2 1/4 to 2 3/8 with a collector muffler.
#1741821
01/29/15 08:59 PM
01/29/15 08:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Max RPM is also part of the equation and the amount your gonna hit it with.. if I were home I could run your engine through my header program to tell you what you need.... but I cant.. its on my other puter
[Re: a493demon]
#1741823
01/29/15 09:25 PM
01/29/15 09:25 PM
MR_P_BODY
http://www.wallaceracing.com/header_length.php
I wouldnt base my headers on that.. it has a good bit of the info needed but it sure doesnt ask all of the data needed... I've been using the header max program for years and have tested it on the dyno
[Re: MR_P_BODY]
#1741824
01/29/15 09:53 PM
01/29/15 09:53 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
505 cu. in. with stainless step headers, 2" - 2-1/8" to 2-1/4" . Merge collectors. Shift at 6100, and cross the traps at 6700rpm.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: What size headers tubes on your B1 combo's *DELETED*
[Re: dvw]
#1741831
01/30/15 05:15 PM
01/30/15 05:15 PM
Posts: 16,923 NC
440Jim
NC
[Re: 440Jim]
#1741832
01/30/15 05:28 PM
01/30/15 05:28 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
i run 2.25 on my dart. i went from tti 1.125 on my engine without the blower and with and it didn't see anything on the chassis dyno
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: dvw]
#1741833
01/30/15 05:32 PM
01/30/15 05:32 PM
Posts: 16,923 NC
440Jim
NC
Though not a B-1 Chuck from best did a header test a while back and posted it. I believe it was an 572 -1. The smaller 2 1/8" were better until the very end of the range like 6000-6500 Doug
I think I found it with the search: https://board.moparts.org/ubbthreads/show...rue#Post8275911
572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results Indy Alum Block Indy 440-1 345CNC Heads Indy 440-3X Intake Quick Fuel 2.125 4500 Carb Re done by Bob Book HVH 2” Spacer T&D Single Shaft Rockers 1.6 / 1.6 BMBBR5 Roller Cam 283 on a 115 Jesel Belt Drive Race Tec Pistons 15 to 1 .043/.043
758 tq at 5700, 939 hp at 7400, TTI Headers 2.125 x 3.5 728 tq at 5900, 946 hp at 7100, 2.125 to 2.375 to 2.500 with a 5" collector
[Re: Al_Alguire]
#1741835
01/31/15 12:33 AM
01/31/15 12:33 AM
Posts: 289 Lowes
steve660
Lowes
Interesting post. Im having 622 with PSO heads built and will need headers. It is a pump gas engine with shift points around 7000ish in a 72 Barracuda. Have been told TTI 2"-2 1/8" step with 3 1/2 collector will be enough. Im kinda skeptical about them. If need be ill have custom ones made.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
