2004 Ram 2500 4x4 transfer case fluid #1740901
01/28/15 01:11 AM
01/28/15 01:11 AM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I think I'm going to change the transfer case fluid in my 2004 4x4 diesel Ram.
What do you guys recommend for fluid...ATF+4? gear lube? mixture?
I believe it holds 2 quarts?
Thanks.
Re: 2004 Ram 2500 4x4 transfer case fluid [Re: KillerBee] #1740902
01/28/15 10:34 AM
01/28/15 10:34 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I use the ATF+4.
Re: 2004 Ram 2500 4x4 transfer case fluid [Re: NITROUSN] #1740903
01/28/15 02:36 PM
01/28/15 02:36 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
It's ATF +4 from the factory.
